Pinion Bearings - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-08-2006, 09:10 PM   #1 (permalink)
Member # 54259
Pinion Bearings
Just installed new carrier and pinion bearings on the front diff of a 1999 GC Laredo 4X4, and when setting the pinion bearings peload I seemd to have over torqued the pinion nut a bit, so I backed off 1/2 turn which now gives me approx 45 inch lbs of preload as opposed to the required 15-35.
Is this adjustment that critical, did backing off of the initial torque by 1/2 turn increase any freeplay anywhere? Can I leave it as is, which is with the backed off 1/2 turn, and the 45inch lbs of preload? Or should I give it 1/2 turn to put back to the original torque, but then I am guessing this would increase my preload to 45-50 inch lbs? Or, should I install a new crush washer and start over?
95 SWB
97 lx450
93 940t
86 930
tdculp is offline   Reply With Quote
Old 12-08-2006, 11:52 PM   #2 (permalink)
Member # 65332
i just finished my first R&P using pirates info, but it was HP44. if it where me, I'd start over and shim it 'bout .005 at least. im not positive, good luck.
fishotro is offline   Reply With Quote
Old 12-09-2006, 06:08 AM   #3 (permalink)
Bending light
BlueAngel's Avatar
Member # 24300
You cannot just back off the pinion nut with a crush sleeve design, the crush sleeve is already overcrushed, you will need to buy a need one and start over.
Project - Destroyer
BlueAngel is offline   Reply With Quote
Old 12-09-2006, 08:50 PM   #4 (permalink)
Member # 291
i would start over cause you have now made the sleve to small and you will eat uo pinion bearings if you leave it.
In The Rear With The Gear...
84scrambler is offline   Reply With Quote
Old 12-10-2006, 11:21 AM   #5 (permalink)
Member # 45193
x2. Many of the install kits even give you 2 crush sleeves now. No way I'd leave it in there.
My build:
/forum/jeep-hardcore-tech/553047-college-budget-buildup.html
Bull Durham Racing
WEROCK Stock Mod East
Team #360
95yj is offline   Reply With Quote
Old 12-10-2006, 07:39 PM   #6 (permalink)
Member # 54259
Thx, Got new crush sleeve and reinstalled.
95 SWB
97 lx450
93 940t
86 930
