Cannot Accelerate - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-17-2006, 07:14 AM   #1 (permalink)
Member # 37794
Cannot Accelerate
Project #2 - 93' 4.0 from Cherokee stroked to 4.5. Original 4.0 ran fine but I thought I wanted a Stroker. I used original intake manifold with original sensors. O2 sensor relatively new. CPS is original mounted to bell housing of AW-4 transmission. It starts great and idles fine but it stalls if I attempt to rev up engine and backfires occasionally. When hooked up to computer, no error codes given. I checked fuel pressure and regulator seems to be working - ~ 35#'s pressure which builds up to ~42#'s with vacumn hose disconnected. I did install a new (rebuilt) distributor. Help!
mguill is offline   Reply With Quote
Old 12-17-2006, 08:19 PM   #2 (permalink)
Member # 4321
Send a message via ICQ to DEnd Send a message via AIM to DEnd Send a message via MSN to DEnd Send a message via Yahoo to DEnd
Check your spark plug wires and routing, Distributor, timing etc... I'd bet its an ignition problem.
Lame Sig Line
DEnd is offline   Reply With Quote
Old 12-18-2006, 12:49 PM   #3 (permalink)
Member # 51692
Send a message via ICQ to rocknbronco Send a message via Yahoo to rocknbronco
are the injectors pumping enought fuel under throttle?
Space for rent sold it all....
rocknbronco is offline   Reply With Quote
Old 12-18-2006, 01:08 PM   #4 (permalink)
Member # 3132
loosen the exhaust at the manifold and see if you can rev it. maybe somebody put something in your exhaust. or maybe something was living in the exhaust and is in front of the cat now.
NOODLES is offline   Reply With Quote
