Bumper thickness - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2002, 11:32 AM   #1 (permalink)
Member # 4897
Send a message via AIM to sanyi83
Bumper thickness
.120 steel is thinner that 3/16th's right? how much thinner? I am thinking of buying this bumper but not sure if I want to spend the money on something that wimpy.
sanyi83 is offline   Reply With Quote
Old 05-14-2002, 11:38 AM   #2 (permalink)
Member # 5393
3/16 = 0.1875.....................
89 YJ in pieces............42's w/ rockstomper beadlocks, CJ front clip & dash, 60/14, 350 with GM TBI, RV cam, and 305 heads 700R4, dana 300, F-150 springs on all 4 corners and 105" wheelbase......
Jonathan M is offline   Reply With Quote
Old 05-14-2002, 03:04 PM   #3 (permalink)
Member # 343
.120 is slightly thinner than 1/8th inch. 1/8th inch would be .125..1/4 inch is .250. Hope that helps. That is kinda thin for a bumper IMHO. john
cj8scrambld is offline   Reply With Quote
Old 05-14-2002, 08:57 PM   #4 (permalink)
Member # 7980
3/16" is ideal, it's lighter then 1/4" which IMO would be overkill and is way stronger then 1/8" which is around .120.
i have built my bumpers and skids and most of them are 3/16" and it's real beefy, 1/8" will not cut it, and i made my rockers of 1/4" i wish i had gone with 3/16" cause they are too heavy and 3/16" would have been strong enough.
HTH
'00 TJ Built, locked, lifted and armored
Sharp is offline   Reply With Quote
Old 05-14-2002, 09:08 PM   #5 (permalink)
Member # 940
My bumpers and frame are all made of .120 and it works fine. You can dent in the .120 if you try hard enough so .188 would be just right. .250 is overkill and just extra weight to me.
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 05-14-2002, 09:17 PM   #6 (permalink)
64Trvlr's Avatar
Member # 6582
I'm building mine out of 3/16" tubing.
Originally Posted by Muddin
You must be able to blow harder than me
Originally Posted by Bubba Ray Boudreaux
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
64Trvlr is offline   Reply With Quote
Old 05-15-2002, 05:26 AM   #7 (permalink)
Member # 2790
Is that for your RC car/truck??and would that be copper-steel -or SS?? I used 3/8 SS for my fuel line and 1/4 SS for my return line..
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote
Old 05-15-2002, 05:45 AM   #8 (permalink)
YJ4RoX's Avatar
Member # 1930
.120 steel is 11 gauge. just a little thinner than 1/8"
IMHO 3/16 is ideal for bumpers and rockers. Although 1/4 is commonly used on rockers. Personally i used 7 GA plate for my rockers it measures .1793" Just a little lighter than 3/16 and it takes a hell of a beating.
For bumpers go 3/16"
YJ4RoX is offline   Reply With Quote
Old 05-15-2002, 07:27 AM   #9 (permalink)
64Trvlr's Avatar
Member # 6582
This is for my Jeep. The 3/16" tubing I was talking about, is 3/16" wall 2"x4" mild steel tubing for the bumpers. The fuel line is 3/8" steel tubing as mine has a carb there is no return line.
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
Old 05-15-2002, 05:35 PM   #10 (permalink)
Member # 4897
I would love to make my bumpers out of 3/16th but I don't have the time for it. And buying bumpers from Bulletproof is out of the question. They are way too expensive. I still might make bumpers. Something I am curious about is how to make the hinge for the rear carrier. and how to secure it so it dosen't rattle. Pics would be helpful.
Old 05-15-2002, 05:59 PM   #11 (permalink)
Member # 764
also keep in mind the thickness of your frame. If your bumper is thicker then your frame what bends first?
arndog
1966 FJ40
cruiser page
arndog is offline   Reply With Quote
Old 05-15-2002, 06:07 PM   #12 (permalink)
Member # 4897
good point.
Also with the rear bumper how would I go about putting in a receiver hitch? Would I have to cut it out of the tubing and weld in a piece?
Old 05-16-2002, 08:21 AM   #13 (permalink)
Member # 11757
Send a message via AIM to slowJEEP
To eliminate similar problems in the future I want to share w/ you a useful trick. Go find a calculator and hit 3 then / then 16. after you hit the = symbol you will get a number. This is the decimal value for the fraction. Subtract the two decimal values and you will find "how much thinner" the steel is.
The first lesson is free.
97 TJ
85 k10 383
slowJEEP is offline   Reply With Quote
Old 05-16-2002, 03:07 PM   #14 (permalink)
64Trvlr's Avatar
Member # 6582
Originally posted by sanyi83
I would love to make my bumpers out of 3/16th but I don't have the time for it. I still might make bumpers.
If you might make bumpers, why don't you have time to make them out of 3/16" steel?
Yes...........................
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
