using CJ motor mounts for a 302 conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2002, 06:48 PM   #1 (permalink)
Member # 3964
well, i finally got my second 6cyl. passenger side motor mount tower. now i just need to figure out what rubber mounts to get. ford or jeep?
i'm using 2 jeep towers and a FORD sb motor. do i get 2 ford rubber mounts or 2 passenger side jeep rubber motor mounts?
any other tips for using this method? i've heard of people having to use washer as spacers.....
thanks- russel
<>< GoAgainstTheFlow
76 CJ7 project- complete change in plans..........2 years in the making and it don't even roll yet.......
olivesman is offline   Reply With Quote
Old 05-15-2002, 09:18 AM   #2 (permalink)
Member # 3964
come on!!! somebody has to know the answer
thanks- russel
Old 05-16-2002, 03:04 PM   #3 (permalink)
Member # 3964
all i can find on the internet is that you use 2 jeep mm's. all the 302 has on it is a 5" bracket w/ flanges on the end and a hole in each flange. there is one bracket on each side.
I KNOW SOMEBODY CAN HELP ME!! PLEASE!!!!!!!
-russel
Old 05-16-2002, 03:10 PM   #4 (permalink)
Grandpa Jeep's Avatar
Member # 1868
Send a message via MSN to Grandpa Jeep
I used a Jeep MM on the right and a homemade mount on the left along with Mustang rubber mounts to mount my 2.3L. Since the 302 and the 2.3L will mount to the same K-member at least in a Mustang, I would imagine you could do the same thing. Here's a writeup on what I did.
http://www.jeeptech.com/oliver/Modif...ns/Engine3.htm
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both
Jeeps, they're not just a hobby, they're a freakin adventure :D
:usa:
Grandpa Jeep is offline   Reply With Quote
Old 05-16-2002, 04:04 PM   #5 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I made my own mounts and re-used the stock poly bushings. I don't know if ths helps you because I swapped in a 350. You can see pics in the Big Yellow Buildup section of my web page.
J. J.
www.PATPARTS.com
Like Patooyee's Parts on Facebook!
https://www.facebook.com/Patooyee
patooyee is online now   Reply With Quote
Old 05-16-2002, 08:30 PM   #6 (permalink)
Member # 1802
Send a message via AIM to emsoffroad
Used stock Ford car mounts in my cj. Then just made the frame mounts using a piece of tube the bolt fits thru, and flat stock. Nice thing about the ford mounts is that even if the rubber goes bad, the motor can't fall out since there is a metal cage all the way around it.
[URL="http://www.emsoffroad.com/store/"]EMS Offroad[/URL]
emsoffroad is offline   Reply With Quote
Old 05-16-2002, 08:56 PM   #7 (permalink)
Mr.N's Avatar
Member # 1635
I knew sereral guy's who ran this. I think only one still does. You'll have to shim the back up around 1.25" and the front .25".
Good Luck (I went this route then made my own)
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote
