Anyone using DOT 5 brake fluid??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2002, 09:09 PM   #1 (permalink)
64Trvlr's Avatar
Member # 6582
Question Anyone using DOT 5 brake fluid???
OK, I tried the search and nothing. Are any of you guys using DOT 5 in your brake system? It works great in mine except for the fact it goes right through the brake light switch in about 6-8 months. I'd like to find a switch ( 1/8" pipe thread normally open ) that would not leak every 6-8 months.
Thanks for any help.....
Originally Posted by Muddin
You must be able to blow harder than me
Originally Posted by Bubba Ray Boudreaux
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
64Trvlr is offline   Reply With Quote
Old 05-14-2002, 11:09 PM   #2 (permalink)
Member # 8109
Send a message via Yahoo to tigger4x
I used the DOT 3 until a few buddies said that they had switched up to the DOT 4 in their street bikes. And I hadn't heard of the DOT 5 stuff before now so I have no first hand knowledge. Are you sure that it is indeed the DOT 5 that is causing the leakage You can always contact the manufacturer and make an inquiry. I dunno.
OSAMA If you dont like the horns dont piss off the bull! Land of the FREE cuz of the BRAVE!:usa:
tigger4x is offline   Reply With Quote
Old 05-15-2002, 01:48 AM   #3 (permalink)
Member # 4321
Send a message via ICQ to DEnd Send a message via AIM to DEnd Send a message via MSN to DEnd Send a message via Yahoo to DEnd
If I remember correctly DOT-5 fluid will leak in a system designed for DOT-3 or below. I don't know of a switch that will work because most of the newer vehicles (at least all that I have seen) have the brake light switch in the porportioning (sp?) block. Though I guess you could take out the porportioning mechanisim and seal off all the unneeded holes if you can find one with the right fittings.
Lame Sig Line
DEnd is offline   Reply With Quote
Old 05-15-2002, 07:20 AM   #4 (permalink)
64Trvlr's Avatar
Member # 6582
Originally posted by DEnd
If I remember correctly DOT-5 fluid will leak in a system designed for DOT-3 or below. Though I guess you could take out the porportioning mechanisim
The system doesn't leak at all. The only problem is at about 6-8 months the DOT 5 seeps right through the switch. My Jeep is an old one and it doesn't have a proportioning valve.
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
Old 05-15-2002, 07:30 AM   #5 (permalink)
Member # 9971
Plug the pressure switch hole and run a regular electric trip switch on the pedals. I run DOT 5 in all my “new” installations its good stuff but is considered “compressible” to some degree.
I swing this old hammer, for a dollar and a half a day….
AKA cornfedred
ol John Henry is offline   Reply With Quote
Old 05-15-2002, 07:34 AM   #6 (permalink)
64Trvlr's Avatar
Member # 6582
Originally posted by cornfedred
“compressible”
I'm thinking about doing that, but was just wondering if anyone knew of a switch that would work. I called Borg Warner this morning and " somebody " is suposed to call me back with some info.
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
Old 05-15-2002, 07:49 AM   #7 (permalink)
Member # 9971
Almost any switch will work <img src= "http://www.partsamerica.com/product_images/AAP/ACD/D885.jpg ">
GM# 01261219
AKA cornfedred
Old 05-15-2002, 07:52 AM   #8 (permalink)
64Trvlr's Avatar
Member # 6582
That might work, have to figure out a mount as my pedals come through the floor. I was thinking about the lever arm style they have on heavy equipment, then it could go under the floor with no problem.
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
Old 05-15-2002, 09:56 AM   #9 (permalink)
Member # 2530
Send a message via AIM to CaptainFleXJ151
Dot 5 brake fluid is generally used for racing because of its high temperature resistance. There is no need for it in an off-road application. If you use Dot 5 you will have to change the fluid often. The corrosion resistance of dot 5 is not near as good as dot 3 or 4. I would stay away from it unless you are racing your rig with multi piston calipers.
John
'87 E30: 2.7, 5 speed, 3.25 LSD, 4 discs, M3 springs/Bilsteins
'89 XJ +RIP+
CaptainFleXJ151 is offline   Reply With Quote
Old 05-15-2002, 10:16 AM   #10 (permalink)
Member # 2769
These things were told to me by Van, a professional power brake man....
DOT 5 is used in motorcycles due to it's high temp resistant properties. And it was used in some of the older postal Jeep models for the same reason.
However, it DOES compress and leaves a softer petal.
And it does not need to be used in general off roading.
And DOT 3 or 4 works better.
... soooo, I use Valvoline semi synthetic DOT4 in my brakes and NAPA DOT 5 in my Lucas/Girling hydraulic clutch setup.
In fact, the clutch MC's instructions recommend DOT5
Jaffer is offline   Reply With Quote
