D35 lock right problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Closed Thread
Old 02-16-2007, 09:26 AM   #1 (permalink)
Member # 33498
I know this isn't "hardcore" but I posted this in the newbie forum a week ago and didn't get any responses that were worthwhile...
I have a 95 YJ with the shitty D35 and a lock right. Whenever I put the Heep in reverse, the locker ratchets. One of the tires doesn't move at all, and the other one is getting almost no power. Has anyone had this problem before with a lock right. I called Richmond, and their response was to open the diff cover and look to see what was wrong! No shit! I opened the diff, but my cross shaft bolt sheared off as I tried to loosen it (it was about to pop off before I even put my wrench on it.)
The only thing that I can think of is that the leading edge of the teeth when carrier spins in reverse are worn down. This doesn't make any sense because the leading edge in forward would be worn before reverse, and why would EVERY tooth be worn? I know, I need to get rid of it, but until I get an 8.8 I need to solve this problem so I can back up out of parking lots.
wiggamoe is offline
Old 02-16-2007, 09:41 AM   #2 (permalink)
Member # 15404
A bent axle housing can cause the same simptoms....
Life begins where the pavement ends!
rcurrier44 is offline
Old 02-16-2007, 10:07 AM   #3 (permalink)
Member # 33498
True, but wouldn't that cause it to ratchet with both clockwise and couter-clockwise torsional forces? The only thing that I can think of that would be dependent on the of rotation would be the teeth on the locker.
wiggamoe is offline
Old 02-16-2007, 10:22 AM   #4 (permalink)
Daves Offroad Supply
RckCrwlr87YJ's Avatar
Member # 35931
If you still have the stock spider gears why don't you put them in there and see if you have the same problem, then you know if it is locker related or something else.
DAVE'S OFFROAD SUPPLY
OFFROAD PARTS & CUSTOM FABRICATION
www.davesoffroadsupply.com
Email: dave@davesoffroadsupply.com
Phone: 484-554-3584
Pirate4x4 Members use Promo Code "pirate5" for 5% off on our website!
RckCrwlr87YJ is offline
Old 02-16-2007, 12:42 PM   #5 (permalink)
Member # 33498
Well, the freakin cross shaft bolt sheared off when I tried to loosen it. It must have partially sheared in the diff, and when I went to loosen it, I barely turned the wrench and it came off. I have to drill the bolt out then bust the cross shaft out.
wiggamoe is offline
Old 02-16-2007, 12:54 PM   #6 (permalink)
Member # 35931
Its a Dana 35......what do you expect.
Phone: 484-554-3584
Old 02-16-2007, 01:04 PM   #7 (permalink)
Member # 33498
Dana 35s suck, but that isn't the point. What is inside a differential that is dependent on whether the carrier is spinning clockwise or counter-clockwise?
wiggamoe is offline
Closed Thread
