Ultimate Wrangler Build Ups and Swaps thread - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-11-2007, 08:34 AM   #76 (permalink)
spot me? mydfghgfff!
gtxracer's Avatar
Member # 25303
Will do, post up a link when you get time.
97 TJ 4.0/np435/d300/3link/4link in progress
Ultimate Wrangler Build Ups and Swaps Thread
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more!
Now incorporating a CJ and Willys section, post your tech and builds!
gtxracer is offline   Reply With Quote
Old 10-11-2007, 02:17 PM   #77 (permalink)
Member # 18456
Send a message via AIM to Builtcj7 Send a message via Yahoo to Builtcj7
excellent thread! I have a CJ, but have been thinking of picking up a TJ a installing a set of 60's. Thanks for having all the research info in one place, I know it was a lot of work.
www.thejostens.com
www.ultimatetruck.com
Builtcj7 is offline   Reply With Quote
Old 10-12-2007, 09:29 AM   #78 (permalink)
Member # 47730
love the new pictures....
a bunch of tube.a v8 and other stuff..
2nuts4u is offline   Reply With Quote
Old 10-15-2007, 01:09 PM   #79 (permalink)
Member # 99246
+1, ive got this thread on my faves list. Ha. good idea man.
Sua Sponte.
samhain138 is offline   Reply With Quote
Old 10-15-2007, 01:53 PM   #80 (permalink)
wildman4x4nut's Avatar
Member # 21893
Mine will be getting some revised axles here in the next few months.
I am going to be putting a LP D60 in the rear and moving my Tera CRD60 to the front.
TJ Builds:[url]www.pirate4x4.com/forum/showthread.php?t=578353[/url]
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote
Old 10-15-2007, 03:19 PM   #81 (permalink)
gtxracer's Avatar
Member # 25303
Wish I could do all of them like that but I can only post 10 images in one reply.
Wildman - make sure to PM or post the link so I can get it in here
Old 10-15-2007, 09:25 PM   #82 (permalink)
Member # 21893
I'll keep you posted. This is not going to be as fast a build due to funds but it'll get done. The plan is to run the SpiderTrax Ultimate 60's knuckles in front & then Solid Full Floater kit in the rear. The rear axle that was given me has a spun tube in it. I am going to get it narrowed to 60" from 67". Then I have to decide if I want an ARB or a Detroit in the rear. Going to stay with 5.13 gears and I just had the one for the CRD Heat Treated & Cryo'd by Bobby Long. I'll get the gears for the rear axle treated too. I am going to have to fab up a bracket for the Nth Degree Stinger. Should be fun but not an issue.
Old 10-20-2007, 07:56 PM   #83 (permalink)
Member # 96769
After reading everyone of those threads, I couldn't find any ideas as to how to get rid of all that crap that sits behind the tail light on the passenger side. I have scoured the net looking for someones directions as to how to relocate the stuff when putting on comp corners to no avail. I need to cut open my wheel wells in the back because my 36" Iroks are rubbing the back of the opening. I also plan to add a fuel cell like the others and move the axle back here in another month or two and I'd like to go ahead and get rid of all that stuff now if it can be done. As of now, I have that whole mess out of there and capped off the open tubes and taped over the electrical plug that went to there and I am showing a check engine light. What do I need to do? Thanks.
Rafartist is offline   Reply With Quote
Old 10-20-2007, 09:28 PM   #84 (permalink)
Member # 94474
great thread!!!!!thanks
supadupaj is offline   Reply With Quote
Old 10-21-2007, 04:16 AM   #85 (permalink)
gtxracer's Avatar
Member # 25303
I'm not really sure what you're asking?
Old 10-21-2007, 04:22 AM   #86 (permalink)
Member # 21893
Pretty easy fix, you need to hook everything back up tpo get rid of your check engine light. And since you have figured out how to take that stuff out then relocating it to your engine compartment shoud be a piece of cake. What is all that stuff? Charcol canister & leak pump if I remember right.
Old 10-21-2007, 06:16 AM   #87 (permalink)
Member # 96769
Yeah, that is what it all is, my question is can I just get rid of all of it? I dont see any of that stuff in the Jeeps that have had the corners cut comp style
Old 10-21-2007, 06:22 AM   #88 (permalink)
Member # 96769
I guess I will go down to the Autozone and some stuff and move it all. I just wasn't sure if I could just take it all out or not. We dont have to go thru emissions checks here in Indiana.
Old 10-21-2007, 10:20 AM   #89 (permalink)
Member # 21893
Well if you want to make the ENGINE to run right and keep your fuel milage then you need this stuff. Has nothing to do with if you have emissions where you live. This isn't the 70's where you can just take crap off because you want to. And you need to do some more searching because there are people who have talked about relocating this stuff when doing a comp cut.
Old 10-24-2007, 03:14 PM   #90 (permalink)
Member # 25392
Here is my build to add to the list "Project DD TJ" /forum/jeep-hardcore-tech/624573-project-dd-tj-build-thread.html
2003 Rubicon 104" wheelbase
tnjeep is offline   Reply With Quote
Old 10-25-2007, 01:57 PM   #91 (permalink)
gtxracer's Avatar
Member # 25303
Added. Thanks!
Old 11-02-2007, 10:53 PM   #92 (permalink)
ahighfivetolife's Avatar
Member # 70117
K, time for the YJ section now...
'73 K5 350/TH350/NP203/14B/D60/5.38/SPOOLED/42's
ahighfivetolife is offline   Reply With Quote
Old 11-03-2007, 02:44 PM   #93 (permalink)
gtxracer's Avatar
Member # 25303
Maybe make another thread for 'em? I'm busy dammit!
Old 11-03-2007, 03:47 PM   #94 (permalink)
Member # 70117
Ya know, I was thinking about it today, but that's a lot of digging! I just may do it though. We have some pretty good builds for the YJ's.
Old 11-03-2007, 06:23 PM   #95 (permalink)
Member # 63225
Well since my pile is in this thread along with other jeeps that are not TJ's is there really a point to have a thread on YJ's?
TeenyCAR is offline   Reply With Quote
Old 11-03-2007, 07:21 PM   #96 (permalink)
gtxracer's Avatar
Member # 25303
The only reason I've included some YJs in this thread is the suspension - which is what the basic difference is between a YJ and a TJ. A linked suspension is much more complicated than leafs. So, if the YJ had a linked setup, I included it. If you guys want to make this the TJ and YJ Ultimate thread, that's fine with me, I'll put in the links. Like I've said before, this thread is to help, so whatever the need is, let's meet it.
Old 01-22-2008, 10:11 PM   #97 (permalink)
gtxracer's Avatar
Member # 25303
Top this biatch!
All you guys with new builds, post 'em up!
Old 01-23-2008, 07:50 AM   #98 (permalink)
Member # 68338
Here is my stretched 1 ton TJ build. It is still ongoing.
Project Patriot
jeeperjosh is offline   Reply With Quote
Old 01-23-2008, 07:55 AM   #99 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
This one is mine.... Another 1 ton TJ (Rubicon) that isn't complete... Good enough to wheel though And WAY over kill for the PNW!
One Ton Rubicon
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 01-23-2008, 09:19 AM   #100 (permalink)
gtxracer's Avatar
Member # 25303
I will add these both ASAP, thanks for contributing guys
