Cant get 4.0 to start - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2007, 09:56 PM   #1 (permalink)
Member # 37548
I have just taken out my stock auto and replaced it with a TF 727. I now can not get the motor to start. Any ideas? Also can somebody post up a picture of their shifter linkage. Also I drilled a and placed my CPS in the new transmission.
bigblacktj is offline   Reply With Quote
Old 05-31-2007, 10:02 PM   #2 (permalink)
Moderator
apeters89's Avatar
Member # 7647
neutral safety switch.
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 05-31-2007, 10:24 PM   #3 (permalink)
Member # 37548
I took the safety switch out of the old trans and put it in the new trans(I think thats what it was) and hooked it up but still no luck. Is there a way to bypass that to just see if it will start.
Old 06-01-2007, 04:57 AM   #4 (permalink)
Member # 87363
If what you took out was at the top of the bell housing that was the crank position sensor and unless you aligned it when you reinstalled it that is most likely you issue.
If it'll crank no start cps
If it won't crank at all neutral safety
BAL4 is offline   Reply With Quote
Old 06-01-2007, 08:17 AM   #5 (permalink)
Member # 37548
It wont crank at all. How do I fix the neutral safety switch?
Old 06-01-2007, 11:33 AM   #6 (permalink)
Member # 87363
ground the center prong
Old 06-01-2007, 04:00 PM   #7 (permalink)
Member # 37548
So pull out the plug and ground out the center prong. I will do this just to make sure that this is the problem.
