#76 (permalink) |
Member # 156230
Wayne,
Getting ready to put new gears in a 14 bolt. I know they have adjustment collars on both sides of the carrier vs. the typical shims used on a dana 60. What are your tricks for the 14 bolt vs. a dana 60 rear end? Also, I got a solid machined sleeve from East Coast Gear Supply to use with shims instead of the crush sleeve as they said this is a better way to go as there is more possibility for error with the crush sleeve. Anyway, I'm actually going to have an off-road fab mechanic buddy of mine set the gears up for me while I watch for some education, but just wondered what your tips/tricks are for the 14 bolt so I can check for them while he does the setup. Also, is a case spreader necessary for the 14 bolt gear install? Thanks Wayne.
'92 YJ, 4.6 stroker, dana 300 w/4:1, 60's, 5.38's, detroits, 101", 40" MT/R's, KMC Beadlocks |
#77 (permalink) | |
Yukon Gear and Axle
Member # 35700
No spreader Spacer is better than crush sleeve
#4502 "The Rental", Team Yukon Gear and Axle Good Seller/Buyer List! www.150Tunes.com www.DiffsOnly.com www.Jeeperman.com 10% PIRATE COUPON CODE: pirate4x4 Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com |
#79 (permalink) | |
Yukon Gear and Axle
Member # 35700
![]() http://www.toolsource.com/wrench-dif...-p-111873.html http://www.pirate4x4.com/tech/billav..._bible/14b.pdf Screw driver can ruin the side adjuster and/or you can't get the correct preload. The 14bolt is kind of tough, because there is no real good method, like there is for the Ford 9" or Toyota 8" or the....
#80 (permalink) | |
Member # 21893
4 years sure seems like a long time. The Jeep has been sitting for the past two years because I got tired of fighting the damn overheating engine. Well and my selfmade Hummer rims BROKE.......................................... So I have my fingers crossed that in the next month or so I will have the funds I need to finally build that 5.9 and fix all the little stuff wrong with the Jeep. So far the rear axle is still working great and no issues. I haven't been around on any of the forums lately for a lot of reasons. Some due to shit from Iraq and others because it is hard to be on here when my junk is broke and I am broke and can't fix my junk. Thanks again, Rick
TJ Builds:[url]www.pirate4x4.com/forum/showthread.php?t=578353[/url] I'm an ASSHAT!!!!!!!!!! Scars are just to remind you of where you have been, Not where you're going. |
#81 (permalink) | |
Yukon Gear and Axle
Member # 35700
#82 (permalink) |
FroBot
Sucks to hear that the project is on hold, but Wayne I have to give ya a huge thanks for the wealth of information you've put into this thread about gear setups. I've been doing my own and for friends for a couple years now, it's not too often you get detailed personal opinions from experienced pros
Dovenosed 5 speed WJ on 9"s and an ongoing won-ton 5.9 ZJ build
#83 (permalink) | |
Yukon Gear and Axle
Member # 35700
