floor removal and placement - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-04-2002, 02:53 PM   #1 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
Location: Tacoma, Wa Where you can drink the water, but don't breath the air
so it's time to take out the old floor, and put in the shiney new one, what's the best way to remove the old floor??? spot weld cutter? air chisel? sawzall? cutting wheel?
look at the shiney new rear floor *bling bling*
I was the five hundred and fourty-second signer of the JV petition, what number were you?
HighHooder is offline   Reply With Quote
Old 06-04-2002, 03:13 PM   #2 (permalink)
Member # 5960
Send a message via Yahoo to LAME
I went with the sawzall for the major removal, then cutting wheel/grinder to clean everything up. Didn't take long at all to get it outta there.
I must say that that is quit a bling bling floor...65% more tite than the one I put in mine
crawl4cure.org
Rock Rash Racing #613, Trail Tampon Spotter
LAME is offline   Reply With Quote
Old 06-04-2002, 09:36 PM   #3 (permalink)
Military Jeeper's Avatar
Member # 2864
Send a message via AIM to Military Jeeper Send a message via MSN to Military Jeeper Send a message via Yahoo to Military Jeeper
At least you can work on your tan in your Jeep with all the reflection......
I take it you aren't replacing the front floor boards, just the back?
79 CJ-5 | SOA | 304/T18A/D20 | D44's | 4.11's | ARB's | HAD Shafts | 35" Toyo MT's |
Military Jeeper is offline   Reply With Quote
Old 06-05-2002, 09:06 AM   #4 (permalink)
Member # 8203
cut -off wheel or air nibblers.
you're gonna put a LIBERAL coat of liquid nails between all that Al and any steel it touches so you don't get a galvanic response.
I take it you planned on blinding other drivers and traffic helicopters?
super cool turbo 4runner
Sundowner is offline   Reply With Quote
Old 06-05-2002, 10:29 AM   #5 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
I'll be blinding ANYBODY that can look down on my jeep and no on the liquid nails, up here we have this nifty stuff called 5200 marine sealant/adhesive, SUPER GOOD STUFF
Old 06-05-2002, 11:48 AM   #6 (permalink)
oldjeep's Avatar
Member # 3511
Here in MN nature takes care of it for you I used a sawzall to take care of the little bit of remaining floor I had before I instaleld my tanning bed.
Chuck P
The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in!
www.oldjeep.com
oldjeep is offline   Reply With Quote
Old 06-05-2002, 12:25 PM   #7 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
if I spend too much time in my jeep in the sunshine will I get a diamond patterned tan/sunburn???
Old 06-05-2002, 12:53 PM   #8 (permalink)
Member # 5960
No, but your ass will look fat.
When are you doing the install?
crawl4cure.org
Old 06-05-2002, 12:58 PM   #9 (permalink)
oldjeep's Avatar
Member # 3511
I don't know, I painted mine black after driving it once - the heat and the glare were terrible. Plus it looked like chrome and that is just plain wrong on a willys
Chuck P
www.oldjeep.com
Old 06-05-2002, 01:15 PM   #10 (permalink)
Member # 5960
For the most part, but the headlight bezels are fine chrome.
crawl4cure.org
Old 06-05-2002, 01:42 PM   #11 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
I've been trying to grow a fat ass for years
The install will take place over the next couple of weeks
The floor is actually starting out in three pieces, the tub, under the seats, and the fire-wall. I still need to cut the piece above to size (the above piece measures 4x7' flat), cut the fronts of the fender wells back, weld on fronts of the fender wells, cut to size and bend (or have bent) the bends in the floor under the seats, and the bend up to the firewall. I also need to construct the sub-frame (2x2x1/4" aluminum box), connect the subframe to the floor, and cut and connect 3/4" angle to the body with the 5200 and some stainless fasteners, then weld the floor to the angle.
Old 06-05-2002, 07:47 PM   #12 (permalink)
oldjeep's Avatar
Member # 3511
I painted them black too
Chuck P
www.oldjeep.com
Old 06-11-2002, 10:08 AM   #13 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
been doing a little cutting, I've removed the wheel wells, ground off most of where they attached to the sides as well. I've cut along most of the perimiter of the floor, but I've left it attached for support. I still have a little trimming left to do on the d/p to make it fit (radius the corners) and then I'll be bending up the floor/firewall section.
Old 06-11-2002, 10:09 AM   #14 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
and...
Old 06-11-2002, 11:04 AM   #15 (permalink)
Member # 792
portable tanning booth
01 TJ
Dan-H is offline   Reply With Quote
Old 06-11-2002, 01:41 PM   #16 (permalink)
Grendel's Avatar
Member # 10448
Send a message via Yahoo to Grendel
We used a grinder, torch and nibbler to remove the floor and hat channel from the CJ-3a. Went with floor panels and hat channel from Jeep Panels plus in Maine. Excellent work.
Grendel is offline   Reply With Quote
Old 06-11-2002, 01:51 PM   #17 (permalink)
Grandpa Jeep's Avatar
Member # 1868
Send a message via MSN to Grandpa Jeep
Got an address or a website for them?
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both
Jeeps, they're not just a hobby, they're a freakin adventure :D
:usa:
Grandpa Jeep is offline   Reply With Quote
Old 06-11-2002, 02:34 PM   #18 (permalink)
Member # 7163
Tel: 207-743-7671
Email: jpplus@jeepanelsplus.com
http://www.jeepanelsplus.com/
Oxjockey is offline   Reply With Quote
Old 06-11-2002, 02:38 PM   #19 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
You're next, eh Oliver???
Old 06-11-2002, 02:42 PM   #20 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
oh, I've been using the angle grinder with cutting wheels and sawzall. then grind smooth the walls... I'm also leaving some floor in 'till the last minute for support
Old 06-20-2002, 02:49 PM   #21 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
this is all of the floor left in the thing now, it'll be gone as soon as I cut out all the spotwelds (there sure are a LOT of them fawkers)
Old 06-20-2002, 02:50 PM   #22 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
even all the way up the firewall...
Old 06-20-2002, 04:02 PM   #23 (permalink)
4xdork
fcfred's Avatar
Member # 3263
a lot of old hotroders would remove the floor of their cars and move them up thus lowering the body around the frame. I always thought this would be a great way to keep a jeep body low over the frame, then just trim the over hanging parts. the benefits being that you could get the belly up and the roof down. buiding your own floor is a great opportunity to adjust all these parts.
good luck
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
ARMY TRUCK STOLEN!
fcfred is offline   Reply With Quote
