Hub bolts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2002, 09:12 AM   #1 (permalink)
Snatch Block's Avatar
Member # 11285
Unhappy Hub bolts
Just wondering, how many of you have snapped these? I have a D60 front with warn hubs, I look down at them and one snapped off & one went for a walk and didn't come back! I run 38.5" SX's if that helps. how hard will it be to get the busted one out?
While your down there, mind giving a ring job?
Snatch Block is offline   Reply With Quote
Old 06-07-2002, 09:42 AM   #2 (permalink)
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
we bust/lose @ least 2 hub bolts per wheelin trip. E-Z Out/hand-drill/spare bolts have become trail tool staples.
oh yeah welcome newbie
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote
Old 06-07-2002, 09:50 AM   #3 (permalink)
Member # 11285
Cool, now when you break them do you replace all of them or just the ones you broke?
Old 06-07-2002, 10:29 AM   #4 (permalink)
Member # 5021
Doesnt matter if you replace them all or not. they will break again. Just do yourself a favor and dont use Grade 8. They will break too and they are MUCH worse to get out. Welcome to the land of external hubs. Sucks to be you
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 06-07-2002, 10:56 AM   #5 (permalink)
Member # 5393
If you can get a set of slugs for the 60 run them. It works for the 44's that have the externally mouned hubs.........
89 YJ in pieces............42's w/ rockstomper beadlocks, CJ front clip & dash, 60/14, 350 with GM TBI, RV cam, and 305 heads 700R4, dana 300, F-150 springs on all 4 corners and 105" wheelbase......
Jonathan M is offline   Reply With Quote
Old 06-07-2002, 11:14 AM   #6 (permalink)
YJ4RoX's Avatar
Member # 1930
a little off topic but:
Is a Snatch block when a chick wont put out?
YJ4RoX is offline   Reply With Quote
Old 06-07-2002, 11:59 AM   #7 (permalink)
Member # 11285
[QUOTE]Originally posted by the TJ kid
If you can get a set of slugs for the 60 run them. It works for the 44's that have the externally mouned hubs......... [/QUOTE
What are "Slugs"?
Old 06-10-2002, 12:10 PM   #8 (permalink)
Member # 3152
Send a message via AIM to Trango Send a message via Yahoo to Trango
Slugs are solid machined pieces that interface between the shaft and the hub. Think of it as "all the time" engagement. It looks like a flattened donut with splines on the outside, like a quarter, and splines on the outside for the shaft. This is a fairly accessible junkyard part - just look for axles with solid endcaps on the ends of the hubs (like the chrome ones on waggy 44's). Beat these off and inside you'll see the slug. Some waggy ones even have lightening holes drilled through them (or are they for grease? weird design in any case).
Bob
Compulsive vehicle builder
Trango is offline   Reply With Quote
