9"/D30 question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2002, 08:54 PM   #1 (permalink)
Member # 8665
9"/D30 question
i can't get the search engine to work so try not to bash me too hard boys
i have the 35 rear and 30 front.
am going to do the 9" rear with detroit and keep the 30 for awhile. i will do a powerlok in the 30 and do the axle/297 ujoints.
this is all the cash i can spend right now.
and run 35" tires.
question is how well does the 30 hold up with this formula?
i am not a basher but do the rock thing a LOT
rockr is offline   Reply With Quote
Old 06-20-2002, 09:23 PM   #2 (permalink)
turtlehead's Avatar
Member # 4790
I ran a 30 open with 35's for 2 seasons with no problems, but be light on the go pedal. I have buddies that ran 30s with ARBs and 38.5 TSLs...but I wouldn't recommend it. The axels and u-joints are the best thing you can do for it with limited funds.
Good Luck
86 Sammy, spring over, 5.38 D44's, 36" SX's, 6.5:1 twin sticked T-Case, full cage, and a cooler full of beer so I can think straight!!!
turtlehead is offline   Reply With Quote
Old 06-20-2002, 09:29 PM   #3 (permalink)
Member # 8958
i going to give you one bit of advise, if you aint moving, dont force it. I've seen a few of my buddies spin their front tires then catch traction and BAM There goes a piece of ujoint. You should do fine, but be light on the gas. I'm going to be pushing 37s on my spooled 9" and an open 30 (for a month or so) until the Dana fairy comes to see me.
[url=http://community.webshots.com/user/abbazappa]small96xj[/url]
whatdaphuk is offline   Reply With Quote
Old 06-20-2002, 10:04 PM   #4 (permalink)
Member # 9960
Hub fuses? I think they withstand 44,000 pounds whereas the axle withstands 55,000. Premium hubs 80,000 to 90,000? Not sure of the numbers. But, what good is strengthening the outside and not the inside? Get some hub fuses for $20 and then you'll most likely have a 5 minute trail fix instead of replacing axles.
Also........the powerlock shouldn't be too harsh on it. It's strong but, it does give. I ran one for years with 33's.
ROKWALKER is offline   Reply With Quote
Old 06-21-2002, 03:20 AM   #5 (permalink)
kpj
Member # 6920
From the sounds of it, he has a "newer" D30 w/out locking hubs. So the hub fuses are out of the question UNLESS he has a hub conversion or I am wrong on the type of axle he has. 35s should handle it just fine for "moderate" wheeling. Just realize what you are asking to do and don't put yourself in a position to test the strength of the axle. I will be running 36s on my D30 until this fall, when I can get either my D44 under the Cherokee or preferably the D60, and am just going to take it slow.
kpj is offline   Reply With Quote
Old 06-21-2002, 03:33 AM   #6 (permalink)
Member # 8665
10-4 on the hubs
don't have any and don't want any
gots the vacuum connect axle and 260 u-joints
being reverse cut gives it some additional strength but just not sure how much abuse it can take. i don't like arb's so figure the powerlok will let the front turn on pvmt and still be satisfactory when wheelin.
Old 06-21-2002, 03:50 AM   #7 (permalink)
Jackstand Wheeler
4Bangler's Avatar
Member # 12152
I've actually broken more axle joints in my Dana 44 than I even did in my stock Dana 30, they are tougher than people give them credit for. What 9" are you going to run in the rear? I'm running an Early Bronco 9" and it's a little too narrow (58" vs 60.5" stock) and my tires are rubbing the frame under articulation, I'm cutting down a fullsize housing and welding my own end housings on to make it a full floater around 62" wide (wms to wms) screw the detroit and get a spool for the rear, in such a light, short wheelbase the Detroit will be banging you around a lot, the spool is only noticeable in parking lot situations. When you replace your front axle, look for an '81 & up Wagoneer Dana 44, it's almost a bolt in.
'46 CJ-2A, '47 CJ-2A, '48 CJ-2A, '50 M38, '52 M38A1, '62 CJ-3B, '62 CJ-5, '65 CJ-5, (2) '66 CJ-5's, '67 CJ-5, '69 CJ-5, '69 J-3000, '70 CJ-101, '74 DJ-5, '74 CJ-5, '77 CJ-5, '78 CJ-5, '78 CJ-7, '78 Wagoneer, '95 YJ, '97 XJ...None of them run.
4Bangler is offline   Reply With Quote
Old 06-21-2002, 04:20 AM   #8 (permalink)
Member # 8665
i am having the 9" built- new style rehabbed housing with new tubes cut to the 60" width. the axles will be 35 spline built by strange. i'll try the detroit and see how i like it. H8(jeff) calls the 9" a PLOW cause of how low the pinion is. i can't afford the HP member and it would be weaker with RC. i was thinking of getting the 8.8 but don't want c-clips.
the 9" should be enough for me at the rear and will handle 38's if and when that day comes. the 30 will have to go by then i am keeping my eye out fot the waggy 44.
this is all for fun wheelin- no competition.
Old 06-21-2002, 07:30 AM   #9 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
I opinion......leave the 30 open. You will learn to wheel better anyway and save yourself a lot of heart ache on broken shit
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
Old 06-21-2002, 07:40 AM   #10 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
I know you don't have a detriot in your D30. BUT, if you put one in Hub fuses are a really BAD idea.
Other than that, Hub fuses suck IMO, I know a guy that was running them, they go so far before the axle goes its not funny. Yeah... its a 5 min fix, one that you may do every few hours depending on the wheeling you are doing.
Travis Waldher is online now   Reply With Quote
Old 06-21-2002, 09:29 AM   #11 (permalink)
Member # 4002
The reverse cut only gives more strenght in the R&P. With 35s, your weak points are your u-joints, shafts and housing and probably not your R&P.
If you plan on keeping the 30 and not worrying about it; truss it, and put some warn shafts with a larger u-joint in it.
Like others said, look for a 81 and up Waggy front in the mean time. JMHO
herzog is offline   Reply With Quote
Old 06-21-2002, 02:53 PM   #12 (permalink)
Aggro's Avatar
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
If he's got a rr30 front, and upgrades axles and joints, exactly what about a waggy 44 is an "upgrade? bigger ring gear, but driving on the coast side, same axles, joints. Sounds like a waste of time. get an arb, alloy shafts, and ctm's and run till ya break-which if you are a competent driver will be a long while.
Aggro is offline   Reply With Quote
Old 06-21-2002, 04:01 PM   #13 (permalink)
Member # 5791
Send a message via AIM to AKJeepGirl2
I ran 36" sx's on my 30 with an ARB(i rarely used it) until my axle munched itself 3 times...luckily my dad paid for a 44, but be gentle with that 30
My tires are writing checks my axles can't cash!!!
AKJeepGirl2 is offline   Reply With Quote
Old 06-21-2002, 05:17 PM   #14 (permalink)
Member # 567
If you run any kind of lift at all and point the pinion at the transfer case it's not a problem. I've run a 9" with a SOA for a couple years now and never hit the pinion.
Sommer family. Four wheeling together since 1972.
Steve Sommer is offline   Reply With Quote
Old 06-21-2002, 06:08 PM   #15 (permalink)
Member # 940
I ran the 30 with 35's for years and had no problems until I started getting on the brakes to lock up the LS and then I started to break stuff. First the ring and pinion and then the LS blewup.
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 06-21-2002, 06:47 PM   #16 (permalink)
moveaside's Avatar
Member # 11983
Who in your opinion makes a strong shaft besides Warn(Superior, Yukon) or are thay just glorified Spicers
My crappy build
[url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url]
moveaside is offline   Reply With Quote
