Member # 53932
One links front and rear......chime in
How many are running some sort of one-link on the front and the rear?
--if only front and not rear or vice-versa, then why? I have searched this topic alot, just trying to get more... Mainly wanting to see the setup in YJ/TJs so I can see where everyone is putting their shocks/panhard bar etc... Thanks in advance. (of course the more pics the better) Keegan |
K^2
Member # 49704
you have seen them WORK amazing or FLEX amazing...because there is a huge difference between the two.
Walle Crawler /forum/general-4x4-discussion/1038946-project-walle-crawler.html Benz Buggy http://pirate4x4.com/forum/showthread.php?t=877869 Slinky Blue Ballz /forum/jeep-hardcore-tech/551947-project-slinky-blue-ballz.html |
What's up keegan? Did you get my old YJ back or what?
I've contemplated the same setup on the TJ and decided against it. I'm going to 4 link the rear with long arms. Poly bushings at the frame end and either 7/8'' Heims or flex joints at the axle. For the front it's 3 link with a pan hard bar.
2012 F150 FX4 EcoBoost - Wanting a built LJ/JKUR Last edited by OkLaHoMaYJ; 11-12-2007 at 08:46 PM. |
Member # 53932
No, the guy ended up selling it anyway, but it is for sale again already lol...im sure something is messed up with it, i dont know...
I still dont have anything yet...keeping my options open. Im gonna build some 1 tons first, buy some parts, then eventually get another YJ or TJ if I find a deal like yours... A shop out here has done alot of one link stuff, tossing around the idea of doing it up front with the rear 4 link...$$$$ is owning me, time to start robbing banks again... |
Member # 57123
leaf spring guy here and thought about the one link set up also but when u really start to understand how the 4 link works u might decide against it, not that the one link set ups dont work for some folks..
____________________________________________ |
Got .45?
Member # 9274
IMHO, one links "work" because the rigs you see them on normally have 44"+ tires 120" WB and v-8 power. with the size of that rig anything would work relative to a jeep with 38's. but when you put apples to apples one links cant hold up to a properly designed off road suspension. hell, its not that much cheaper. also you dont have any adjustments in a one link so i hope it works like you want the first time.
grader ball or huge rod end = $250+ 3 link rear = 4 bushings (nice ones) $50 3 flex or rod ends = $150 whats the problem?
94 YJ w/ 5.3L, TH400, Atlas, and 42" Pitbull Rockers |
#12 (permalink) | |
I think they are just very unadjustable. You gotta be spot on otherwise they suck.
~Philip Midwestern 4x4 Parts Quote:
89 S10 Truggy |
#13 (permalink) |
I'm saving a little $$$$ by running 2''x2'' square tubing for my links. I'm making my own bushing sleeves and buying the Poly bushings locally for pretty cheap. The 7/8'' heims or 3/4'' Flex Joints are going to kill me. I found some beefy flex joints, I think RE, with weld in bungs for $60ea. I'll need 8.
2012 F150 FX4 EcoBoost - Wanting a built LJ/JKUR |
#14 (permalink) |
Mine!
Member # 63664
I've done a lot of reading on them too and it seems that the people that really like them are running them front AND rear. The folks that don't seem to be the ones running them just on the rear with leafs up front. In my very uneducated opinion, I think this is because the leafs up front create an unbalance suspension.
The strength question has (and will) be argued to death just like "poo pipe" cages. |
#15 (permalink) | |
Got .45?
Member # 9274
think of it this way: leaf springs wear out every ~ 2-3 years $600 for a quality set. socks last 4~5 years (nice ones) 4 @ 75$ ~ $300 then throw in ubolts, bushings, track bar ~$300+ Coils springs never die and are free most of the time socks if using coils ~$300 links wear out but rarely if you buy high quality ones ~$500 if you use coil overs/air shocks they are rebuildable. 4 @ $250 (air shocks) hardware $100 - 300 (lets say $200) leafs = $1200 Coils = $1700 (w/ air socks) yeah my numbers are skewed but its not THAT much more.
#16 (permalink) |
Member # 96629
Just punch the numbers into the 3-link calculator and decide for yourself.
edit: you must have excel 3 link 4 link
4 Door Tube-J stretched to 127"-5.7 vortec, th400, 203/lomax 205, Rockwells, 18" Fox's & 47" LTBs Last edited by BFJ; 11-13-2007 at 09:59 AM. |
#17 (permalink) |
Member # 11736
I have been running a one link in the rear for 2 years now with much success. I went this route due to seeing other people use this and being able to put so much power to the ground as opposed to the leaf springs I had been running. I wanted to do a one link over a four link due to the cost difference, one joint for $80 or 8 joints at $30 and most four link system I have seen are going to bend a lower control arm at some time or another. I have landed hard on my arms and have yet to bend them.
Flex is pretty good, the link system is not the limiting factor, it is more limited by the springs and shocks. ![]() This is the best picture I have showing how I built mine ![]() I have tried to figure how to build a one link in the front and it seems that there is just not enough room on a compact build to properly design one. Last edited by oh well; 11-13-2007 at 10:13 AM. |
#18 (permalink) |
K^2
Member # 49704
Why is it every time i see a pic of a one-link set-up its of the rig either on its side or on its lid. Is it just me or does this say something about how they work?
Walle Crawler http://www.pirate4x4.com/forum/showthread.php?t=1038946 Benz Buggy http://pirate4x4.com/forum/showthread.php?t=877869 Slinky Blue Ballz http://www.pirate4x4.com/forum/showthread.php?t=551947 |
#19 (permalink) |
"oh well" I have a few questions for ya.
What square tubing are you using for the one link? What joint are you using for the one link? What rear coils are you running? and can we get a closer shot of your one link? Thanks if you can help out at all and the rig looks pretty sweet.
#20 (permalink) | |
Member # 11736
#22 (permalink) |
Member # 33026
I'm building a one link with 2x2x.25" square tube, one 1.25" Summit Machine joint, two Firestone 6x23" 14" travel airbags. If it sucks I only have to buy couple more Summit joints and make it a 4 link.
83 CJ9 TBI350/TH350/231/D300 8274 D60/14b, 15" airbags 39" PBMD 94 F350 460 165"wb towpig |
#23 (permalink) | |
Member # 18543
if you're talking about spending $600 on a set of leaf springs, you're obviously one who is out to do the thing right. That means not using free junkyard coils, and it also means your link materials alone are going to cost a whole trunk load more than $500. Hell, just 16 shanked flex joints will run you upwards of $1k, not including DOM or inserts. Air "socks" also aren't really gonna cut it on a heavier rig, so coilovers move into the picture. Now you're talking $400 a corner (new), not including coils. Call it 1500 bucks for a set of c/o's if you're lucky and get em used(or a different brand, etc), or $1k for air shocks. That makes it about $3k to link it correctly with c/o, $2500 with air shocks. On the flip side of that, if you're a guy ok with running junkyard coils and you can (want) to build $500 links, then you can get leaf springs for FREE just as easily. Now your only expense with the leafs is a set of new u bolts, which would run ya bout $60 for the whole vehicle. you also don't need a trackbar with leafs. the only added expense may be a set of traction bars to save your leafies, and if you use NICE parts, that should run ya about $200 for the whole vehicle, and those don't wear out. by the way, coil springs will wear out just like leaf springs. nothing has an infinite lifetime. So...if you're going to spend $1200 on leaf, i think you'd be actually spending about $3000 on coils. If you're goign to spend $1700 on coils, i think you're actually going to spend about $360 on leaf. Its all about how far you take each design. You can do each one cheap...just don't compare one design's cheap setup to another design's expensive setup. The one link may save you a little $ on link costs, but i think you more than lose that advantage when it comes to adjustability and stability. Last edited by paulkeith; 11-14-2007 at 06:10 AM. |
#25 (permalink) |
Member # 49468
I am seriously considering building a one link out of 2x2x0.25 with a 3" Currie Johnny Joint on the end... I figure a one link won't end up costing much more than building a ladder type antiwrap bar for my current leaf springs, and they both create antisquat anyways.
