Member # 8830
I'm still not sure which engine to put in the Jeep. Everyone seems to have their favorites. I had a 4.0 L that was built by Clifford that put out impressive #'s for the 4.0.
However, since the fire, I want to rebuild bigger and better. I want to run the NV4500 and an Atlas 2 with my dana 44 and 60 (4.56's). I really wanted to keep it Jeep and stay with the 5.9 360, but I haven't seen too many parts available for the swap (wiring harness, engine mounts, etc). On the other hand, there is a ton of stuff on the Chevy 350's. So, how do the two boil down when you look at HP, torque, available parts, ease of installation, maintenece, and gas mileage(yes, don't laugh. I have to get it to the trails some how). Engine has to be fuel injected. Since the fire, I have no engine parts or any wires, so the harness will have to be complete. If you can recommend a reliable place to get the engine from as well, I'd really appreciate the suggestions.
MARSHY CREEK ROCK CRAWLING TEAM |
Member # 8203
dollar for dollar, you can build 2 350's for the cost of one 360.
if you're using an NV4500, you can also use a stock GM bellhousing instead of an adapter.
super cool turbo 4runner |
Member # 5115
Or if you ran the Chrysler/Jeep 5.9 from a Grand Cherokee, you can run the factory bellhousing for a Dodge NV4500. No adapters. It WILL be cheaper running a Chevy motor, just because of parts availablity. If I was going to run a Chevy motor, I would seriously look at the Ramjet 350. This to me looks like the best way to go with Fuel Injection already included. Get the MORE motormounts and run a couple wires to the motor and your off to the races...
Member # 6007
5.9L
It's a good motor that is amazing off-road when you demand power. We have one in our competition TJ. PM me and I can put you in touch with the owner who did the swap himself. He has it all figured out and could do it easily now (or pass on the knowledge).
4-Seats of Fury LS1, 700r4, Atlas 3.0, 2.5 SAWs, Reds Lead Foot Syndicate |
Member # 6007
RSQ I just PM'd you all the info. Just give them a call, ask for Buddy, and he'll take care of you.
Anyone know what auto transmissions they use behind the tpi 5.9 in a newer Grand Cherokee?
#419 8.8876 @ 76.80mph in an 1/8 drag Look for us on Facebook [U][B][COLOR="Red"]Sponsors[/COLOR][/B][/U] Fourward Motentum Driveline Specialists BFGoodrich Art Carr Performance Products Advanced Adapters PSC Motorsports Allied Wheel East Coast Gear Supply Bulldog Winch Reid Racing Inc Last edited by syko; 06-26-2002 at 08:24 AM. |
5.9L, the 360 is what you could call a true truck engine. Right out of the box, plenty of low end grunt. I would say more so than a stock 350, (comparing two stock engines side by side)
The 350 is cheap, no arguments there. But, personally I feel the 360 is better, just 2-3x as expensive. |
#10 (permalink) | |
Member # 8203
Member # 5577
For a TJ the 5.9 would probably be the better choice for no other reason than the fact that the computer operates on the same bus architecture that the 4.0 computer does so you're gauges can be made to work with a lot less fuss.
I still think the 350 is a better engine though... Jake
It's all here before your eyes / Safety is a big disguise / That hides among the other lies |
#12 (permalink) | |
Member # 5577
#14 (permalink) | |
Member # 6007
#15 (permalink) | |
Member # 5577
#17 (permalink) | |
Member # 603
Having said all that, if it were me it would all boil down to price & ease of installation. I don't think the performance "difference" is enough to warrant one over the other. Just my $.02. TEX
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
#18 (permalink) | |
It was the same price as a 350. All machine work, crank exchange, head exchange, and parts were exactly the same as the 350. The AMC 360 was actually cheaper than my AMC 304 to buld, because of parts prices, so the problem of which one to build was a no brainer.
{Gramma from Squidbillies} Lets put coughdrops in our buttholes and play viddy games! |
#19 (permalink) | |
Member # 8203
the rebuild kits are more expensive that 350's by far, and of couse the machine work cost the same. a machinist doesn't care what brand a block is, he's still gotta bore 8 holes in it. when you "Build" an amc, as in look for performance parts, the hurting starts.
#20 (permalink) | |
Member # 5115
#21 (permalink) |
Member # 6007
Hey RSQ
Any word on that 5.9L donor TJ you were talking with Buddy about yesterday????Good Luck!!!
#22 (permalink) |
Member # 12158
The 350 is more "bolt in" due to motor mts, harnesses, block huggers etc. There may be extra costs involved with adapters etc.
I swapped a 5.2 mag in my CJ7 three years ago- no regrets. Around here the chrysler stuff is cheaper cause everyone wants a chevy. I had to fab the motormount and tweaked the factory harness. A 300 will fit right on the back or a 231 if you need to drop on the driver's side. The 300 does need to be spaced a bit- good job for a clocking ring. Most of the Jeeps use a 44RE which is based on the 904 and has better DS clearance on the drivers side. The trucks use the 727 based 46RE which is stouter but more worrk with the DS. All these engines are multiport which I like vs throttle body, they also come with a gear drive starter wich is a nice plus. Good luck!
Ken Blume Rock Rod Racing Team #192/4192 Thanks to our partners Maxxis, Trail-Gear, Yukon Gear, Goatbuilt, Tom Woods Custom Driveshafts, Ruffstuff specialties, Warn Winch, Rokit Enterprises, Viair, Edge Perf., Branik Motorsports, PRP seats, 12V unlimited, Bailie built, Baertrax, Raceline |
#23 (permalink) |
Member # 8830
Well, Big Dude, thanks
So, I am now looking into the chevy 350. I was kinda thinking about getting the engine from the firebird since my original Jeep was burned in a fire. ha ha ha. I've gotta find some reason to install the 350! I am also looking into Buddy's Jeep. It is bad! I'm thinking about it because it took my 7 years to build mine and some punks burnt it in one hour so I don't want take another 7 years to build another beast. Their shop does real nice work, too! So, any are there any fuel injected (no throttle body) Chevy 350's I should look for or avoid? Any good salvage yards to hit up on the east coast? I shouldn't rebuild my 4.0L right?? Never know what fire can do to an engine! Thanks for all of your ideas. |
#24 (permalink) |
Member # 5577
Well (Depending on how much you wanna spend, of course), might I humbly suggest you look into the Ramjet 350?
#25 (permalink) | |
