Dana 44 front disk Chevy/GM Caliper brkt help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-08-2007, 06:12 AM   #1 (permalink)
Member # 25118
I am building a HP Dana 44. Have done Chevy high steer knuckles and want 5x5.5 bolt pattern.
In doing the Chevy/Ford brake combo I have found that there are at least two Caliper mounting plate backspacings. I am told the backspacing is about 1/4" difference. I have caliper brackets with the less backspacing and cannot fit the
brake shoe between the disk and the caliper mounting bracket.
My question is what vehicles do I get the caliper mounting brackets from that will give me the additional 1/4" of backspacing?
Thanks in advance for the help.
motorman is offline   Reply With Quote
Old 12-08-2007, 07:34 AM   #2 (permalink)
Member # 343
I see your problem...and you'll never get brake shoes to work with a disk brake setup. Which Chevy caliper bracket are you using 1/2T or 3/4T?
cj8scrambld is offline   Reply With Quote
Old 12-08-2007, 09:08 AM   #3 (permalink)
Member # 86120
1/2 ton brake brackets
I founed these on ebay. They are exactly what i used. You should be able to find a ton of these at any salvage yard.
http://cgi.ebay.com/ebaymotors/DANA-...spagenameZWDVW
'93 YJ stretched to 108" 4.0L auto w/231/300 cases 60 front 14b rear on 39.5 Iroks
ruebelr is offline   Reply With Quote
Old 12-08-2007, 01:04 PM   #4 (permalink)
brewchief's Avatar
Member # 71185
What spindles are you using? The chevy ones will work, the fords will not as far as I know.
Brewchief
The drum brake ford spindles are what I'm referring to, the disc brake won't bolt up.
brewchief is offline   Reply With Quote
Old 12-08-2007, 02:08 PM   #5 (permalink)
WATERKNIFE's Avatar
Member # 83941
You need to make sure you have the small chev spindle. Either chev backing plate will work with the right spindle.
LS2 buggy build in progress.
05 LS2, 60 front 70 rear TH400, 4.3 ATLAS, 16" SAW Coils, 2" SAW Bumps, 44 TSL's
build pics
http://s223.photobucket.com/albums/dd249/WATERKNIFE/
WATERKNIFE is offline   Reply With Quote
