Member # 25360
Chevy header question for my yj
I've got a 91 5.7 TPI motor in my jeep and a set of these headers. My problem is that the ports on the motor look to be square and the ports on the header are round. I wouldn't think it would be correct to run these headers, but I'm not sure. Does anyone know for sure or know of a similar set of headers with the correct square ports?
1989 Wrangler -- Working on it - 6.0 LQ9 - TH400 - AtlasII 3.0 - Ford D60's w/ 5.38's (chromo 35spline throughout with rear ARB) - 39" Red Labels |
Member # 52488
I run a TBI 383 stroker in my YJ and had the same issue but it's not a problem. I tried the header style that you have and had some clearence issues so I went to the block hugger style with the collector coming down in the middle of the header. My shop ran one tube under the pan and made a custom Y pipe so I could run a single muffler out the back. (no drive shaft issues or clearence problems.) I'm running a TH-350 tranny as well with the stock case but am switching to a 205 T-case soon. I also moved the stock tank into the bed area so now I can run any exhaust I want. If you still have the stock tank, it's best to run your ex.. tube along the passenger side with 1 tube other wise you wont have any clearence. Good luck. Have you done any drive train upgrades?
87 YJ, 4:56s 1tons, 383/350, 205 T-case. "If you don't want it broke it, DON'T Let me drive it"!!! |
Member # 25360
So you are running round port headers on a square head? If so, what gaskets did you use? (round or square, and alum. or copper)
I'm running a ford hp 60 front and 60 rear and a flipped D300. I've got a fuel cell behind the back seat also.
Member # 52488
I used the round gaskets that came with the headers. Soak them in a bucket of water over night before you put them on. mine are still sealing fine and have been on for over a year.
