Member # 12535
Front axle swap
Has anyone ever done a 10 bolt into CJ axle swap or seen website of that swap? I just picked up a 10 bolt front and 12 bolt rear for song and am lookin for info now. Thanks.
85CJ-7 AMC 360, T-18, Dana 300, 4.10 gears, locker rear, 35x12.50-15 Pro Comp Xterrains. Soon to swap in 10 bolt front and 12 bolt rear axles. |
I know a guy that put a 10 bolt front in his CJ, he just moved the perches outboard a little bit. If you can weld, it's not a problem. As for the 12 bolt, if I were you I'd rather go with a 6-lug semi floating 14 bolt. It's stronger. I got one for sale too
99' ZR2 Blazer, SFA 79' F250 Dana 44 with chevy outers, 4.88's detroit, 14 bolt FF, 4.88's, detroit, 3.5" YJ springs in front, customs in rear, 36" TSL's |
#5 (permalink) | |
#6 (permalink) | |
give me some more info on it. and if it is really good I have some family coming down for the holidays from Chapel hill, don't know if they would be passing you on the way to atlanta, GA but ...... |
You will need to outboard the springs on a cj0-7 or have the axle cut down to macth your spring.
Personally a 10 bolt and 12bolt compo is not worth the time, they are both very weak axles. 12 bolt being c clip etc..
KI6PZZ, One of the wheelingpiazzas. Dysfunctional Rockcrawlers (TDO) |
#8 (permalink) | |
Member # 784
This is a SF 9.5 14 bolt. 33 spline, c-clip axle
Think for yourself |
Member # 12535
The 10/12bolt combo sure beat the strength of a dana 30, amc model 20 combo. Since I'm not into hardcore rock crawling, I figure that they will be fine. Thanks for all the input so far.
Jackstand Wheeler
Member # 12152
I think the 10-bolt front is a decent choice, comparable to the Dana 44, only easier to work on (don't have to remove ring gear to get the spiders out) but the 12 bolt rear is a dumb move, the c-clip axle design is just not good for what we do. The semi-float six lug 14 bolt is a little stronger, but still c-clip, and not many lockers available. If you don't think you need eight lug (real 14 bolt), look for a late 80's Jeep J-truck, some had rear Dana 44's, similar width to full size Chevy, and 6-lug. Even a six lug flanged AMC 20 from a J-truck would be better than the 12 bolt Chevy. Some early ('62-'66) Chevy trucks came with rear Dana 44's, but they are narrower than the later truck axles (around 63"-65")
'46 CJ-2A, '47 CJ-2A, '48 CJ-2A, '50 M38, '52 M38A1, '62 CJ-3B, '62 CJ-5, '65 CJ-5, (2) '66 CJ-5's, '67 CJ-5, '69 CJ-5, '69 J-3000, '70 CJ-101, '74 DJ-5, '74 CJ-5, '77 CJ-5, '78 CJ-5, '78 CJ-7, '78 Wagoneer, '95 YJ, '97 XJ...None of them run. |
