YJ steering wheel disconnect - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-11-2008, 10:17 AM   #1 (permalink)
Member # 67157
I need to order a pinless hub for my steering wheel disconnect and can't get my hands on my rig for a while. I need to determine if the shaft is 3/4 or 5/8. Will be going on an '87.
Searched and found some things about different hubs but nothing on shaft size??
SPOA87YJ is offline   Reply With Quote
Old 01-11-2008, 10:34 AM   #2 (permalink)
Rubicrawler's Avatar
Member # 2037
IIRC my '91 was 3/4". I eventually pulled the stock column (should have done this in the first place) and went with a 3/4" tube and u-joint assy from Day Motorsports and was able to reuse my quick disconnect.
edit: http://www.daymotorsports.com/product/357/ Great service and delivery!
Mark Langford
KI6TMK
'86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's
Dysfunctional Rockcrawlers (TDO)
Rubicrawler is offline   Reply With Quote
Old 01-11-2008, 01:11 PM   #3 (permalink)
HokieYJ's Avatar
Member # 93090
The YJ shaft is a 36 spline GM shaft. A Grant #3001 is a direct bolt on to a stock yj column. I'm running one in my YJ.
Ben
http://www.4x4grace.com
Jeep Wrangler with some bolt-on "stuff"
4.3
700r4
Atlas 3.8
D60/Sterling 10.5, 4.56s, welded
37" Trepadors
'97 Cummins 3500 12v/5spd/4wd S&B intake/ 5" turbo back
Project "Redneck Rock Rod" build thread
HokieYJ is offline   Reply With Quote
Old 01-11-2008, 01:19 PM   #4 (permalink)
Member # 37136
Send a message via AIM to PolarYJ
where'd ya pick that up from? did ya find a good price?
YJ: d44/12b(4.56, truetrack/detroit), 2"BDS springs/SOA, d300, 4.6 stroker, cage
PolarYJ is offline   Reply With Quote
Old 01-11-2008, 01:23 PM   #5 (permalink)
HokieYJ's Avatar
Member # 93090
I got it from Summit it was $130 or so. A little pricey I guess, but it seems to be a good quality piece.
http://store.summitracing.com/partde...5&autoview=sku
Ben
4.3
700r4
Atlas 3.8
37" Trepadors
Old 01-11-2008, 02:01 PM   #6 (permalink)
Member # 67157
Cool, thanks for the good info. Looks like just the pinless hub is $170 by itself. Not trying to skimp out here, but that is way out of my price range. I've found numerous other hubs ranging from $20-$80 that seem to be of equal quality but only specify 3/4 or 5/8. Does anyone have a concrete measurement on their shaft?
Old 01-11-2008, 02:03 PM   #7 (permalink)
HokieYJ's Avatar
Member # 93090
I'm 99% sure it's a 3/4" shaft. The thread on the end of the shaft is a 5/8" thread.
Ben
4.3
700r4
Atlas 3.8
37" Trepadors
Old 01-11-2008, 02:11 PM   #8 (permalink)
Member # 2037
Stock is a 3/4" 36 spline. Same as a Chevy column
Mark Langford
KI6TMK
Old 01-11-2008, 02:20 PM   #9 (permalink)
backyard wrenchers's Avatar
Member # 81935
this is the same as above, the grant disconnect
Keen Motorsports #125
Thanks to our sponsors: Appalachian Offroad Inc and Clayton Offroad Manufacturing
Originally Posted by zachv View Post
I bet that will be the first rig ever with King coilovers and a C-channel truss!!
backyard wrenchers is offline   Reply With Quote
Old 01-11-2008, 02:57 PM   #10 (permalink)
Member # 67157
Thanks guys!
