Member # 106311
I want to mate a Dana 300 to my T-18
I am looking for someone who has joined a Dana 300 and T-18 already. I have a Dana 20 on it right now and am wondering what it really takes to do this right. I know someone out there has done this before and might be willing to give me the 411 on this. Thanks ahead of time.
Member # 7588
Novak or advance make the adapter but there is a factory T18 to Dana 300 adapter... it was used on 1980 Scouts....
1948 Willys 1952 M37CDN Powag |
I have a T-18 to a Dana 300 right now in my 84' CJ7. The holes for the T18 mounting are already there almost-you only need to drill a few. The dana 300 connects right to the T18 with an adapter from Novak or Any other company. There isnt much too it really, just install the adapter and mate the Tranny to the Transfer Case. This combo works great for me.
1984 Cj-7,Currie 9" rear,Waggy dana 44,35's,4.56,fuel injected Inline 4.2,AGR steering, dana 300,t18 |
#5 (permalink) | |
This is the Novak where you change the output and backplate?? I emailed Novak about it couple months earlier... no reply from them yet. My question was will the kit fit a T98A, wich is the previous version T-18A and how much longer would it be compared to stock. How long is a Stak 300 with a tom woods flange?
74 CJ5/06 4.0/T18A/TS 20 3.15/HP44 4340 ARB 4.88/HP60FF detroit/4link antirock/38TSL dbl bdlk/90.5WB |
#6 (permalink) | |
Member # 55912
Per
JEEP J20 -77 |
#7 (permalink) | |
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
You are going to need to change the output shaft inside the tranny. He has a Dana 20 mounted to the T-18. They use different shafts. Novaks kit comes with the shaft and the adapter. changing the shaft is not that hard.
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. |
Member # 6340
That is correct as the IH 300 is basically a Dana 20 case adapted to the Dana 300 internals.
#9 (permalink) | |
Member # 6340
If you have a Ford t-18 you will still need an adapter.
Why not go directly to novaks sight and look, http://www.novak-adapt.com/catalog/kit_183.htm
ur T18 to Dana 300 conversion makes for a strong, refined, compact geartrain assembly both on-road and off-road. It is one of the most persistently popular manual shift transmission conversions into Jeeps, providing a very compact geartrain, an excellent crawling gear, compatiability with several engines and simple installation. Adapting the T18 & T19 to Jeep Transfer Cases Kit 183, adapting the T18 or T19 transmission to the Jeep Dana Spicer Model 300 and FSJ New Process transfer cases Part: #183 Weight: 17 lbs. Price: $506.20 Options: Options: Buy: Notes: Includes the adapter, transmission mainshaft, seal, gaskets, steel mount base, fastening hardware & instructions The adapter kit is also desinged for compatibility with the Jeep NP208, 219 & 229 transfer cases as found in Full Size Jeeps, 1980-1991. The Adapter The Novak T18 / T19 to Jeep transfer cases adapter is very compact at only 3.2" long for a combined transmission and adapter length of 15.2". The adapter itself is cast and machined of a high-grade aluminum alloy, featuring thick flanges, a heavy cross-section and strength-adding gussets. T18 / T19 Versions Any versions (Ford, Jeep, IH - 2wd or 4wd) and year of the Borg Warner can be adapted to these transfer cases. Transmission Mainshaft Replacement Included with the kit is a mainshaft for the Borg Warner transmission. Replacement is largely straightforward and instructions are included. We also recommend our basic gasket & seal kit, or our all-inclusive master rebuild kit, depending on your assessment of your transmission's condition. See our T18 parts page for information on these items. Transfer Case Input Shafts All Jeep Dana 300 (and FSJ New Process) transfer case input shafts / gears feature 23 splines. Our included mainshaft will spline in directly to these input shafts with no transfer case modifications required. Urethan Rear Mount for the Adapter Kit Mount, rear, transmission, polyurethane Chevy / Jeep / Novak style Part: #RMU Weight: 1 lbs. Price: $36.80 Buy: Transmission Rear Mount This transfer case adapter's design is based on Novak's Universal Series adapters that feature a modular mounting and support system. Included with the adapter kit is a steel base that is a highly configurable mounting foot, and is ready to accept our industry standard urethane isolator mount, available for purchase (below). This is our preferred rear mount unit. Our kit is designed for it, and its usage is essential to protect powertrain components from the flex and jar typical of any automobile, but especially Jeeps. Whether you are assembling onto a stock cross member / skidpan or if you are setting up a high-clearance skid plate, you will find it to be a clean and simple process. Engine Crank to Transmission Pilot Bushing Many manual transmissions will be married to stock as well as conversion engines, and a custom pilot bushing will be required in many instances. Some common choices with the T18 / T19 transmissions are listed below:
KI6PZZ, One of the wheelingpiazzas. Dysfunctional Rockcrawlers (TDO) |
Member # 43184
One the one T-18/300 we did into a cj7, we just went with the t-18 from partsmike already rebuilt and set up for the 300. So, I cant really comment on whats involved in the rebuilding and changing the mainshaft.
The pair did mate up perfect, and the AA adapter had two sets of mounting holes, allowing us to clock up a few degrees further. The adapter is a bit long, and did result in us using a super stubby 13" CV shaft in the back. We recently stretched the rear out 4" to get a little driveshaft back. In a 7 its not likely as much of a concern. |
#12 (permalink) |
Member # 47826
https://eshop.advanceadapters.com/co...02-50-7502.htm
follow link, then Scroll down and click on "click here for assembly instructions" or follow this link: http://www.advanceadapters.com/instructions/50-7502.pdf
Thean Bellocchi [URL="www.polyperformance.com"]www.[COLOR="Red"][B]P[/B][/COLOR]oly[COLOR="Red"][B]P[/B][/COLOR]erformance.com[/URL] [email]Thean@PolyPerformance.com[/email] |
#13 (permalink) |
Member # 55912
I got friend that sells a -80 IH 6 spline D300 for a fair price, is the D300 that much more fun than a D20?
my ratio would go from 67:1 to 86:1 that I understand but otherwise? Sorry for hijacking the post. Per
JEEP J20 -77 |
#14 (permalink) |
Member # 9233
I am getting everything together right now to do the same install.
If you want to go with the Scout setup, there is a guy in Oregon selling a T-19 and Scout Dana 300 for $750.00 obo. Sounds like a decent setup /forum/engines-trannys-t-cases-sale/670825-ford-t-19-dana-300-a.html The T-19 is synchroed first. I am going to go with the Advance Adapters setup and find a standard Dana 300 so that will give me the option of moving up to an Atlas or Stak later if I wanted. /forum/motor-tranny-t-case-performance/616804-advance-adapter-blow-out-sale.html Rockbuggy supplies has the best price on an adapter so far. |
#15 (permalink) | |
Member # 21437
You wouldn't happen to know if that case has a different casting # or not? I pm'd a couple people about what casting # the Scout 300 case had, and no one had a case actually in their possession anymore or it was in deep storage. |
#16 (permalink) |
Member # 20092
The fastest way to ID a Scout 300 is to look at the speedo cable attachment. On a scout 300 the speedo cable comes out on the passenger side. It also has an aluminum tail housing.
A scout 300 will bolt directly to any Jeep t-18 as long as the bull gear is 6 spline. There are some auto versions that I believe used the 10 spline bull gear- but they would have been bolted to a 727. Don't quote me on that part though...... These things are uber rare...why would someone want to run one and risk breaking it on the trail? Finding a replacement would be next to impossible and the 2.61 low range is not *that* much better than a D20. Anyways, you would probably have better luck rounding up the parts to convert a Jeep D20 to the 2.46 low range by sourcing the bronco D20 bull gear and Jeep D18 cluster gears. For the cost, it makes more sense to spring for an Atlas and be done with it.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074. |
#17 (permalink) | |
Member # 21437
I also have unanswered emails and pm's that are over 6 months old that are from people who take large dirty pictures of Scout 300's or clean satellite pictures...... I would assume the casting would start with D300..... but if it is actually a modded D20 casting...... It would be a shame to find out after the scrap truck shows up, which will be some day. |
#18 (permalink) | |
Member # 10066
You still have to buy the same $500 plus adapter to put an Atlas behind a T18 as you do a Dana 300 |
#20 (permalink) |
Member # 9233
Not everyone has unlimited budgets.
I am doing engine and steering upgrades at the same time so my budget will be spent for a while. I plan on running the 300 case for a season or two and then save up for an atlas or stak. I should be able to get the money back out of the Dana 300 when I go to resell it. |
#21 (permalink) | |
Member # 20092
of course, there is always the automatic swap. It's possible to adapt a D300 with no aftermarket adapters
#22 (permalink) | |
Member # 6340
Yes it is a different case. I do not know the numbers.. You might try the Bender Bulletin board. they may be able to get you the numbers
