Member # 84246
YJ on 404's
YJ on 404’s
This build has been somewhat ongoing for the past two years, but I think it finally is going to start to get interesting. I started with a 93 yj 4.0 which I have had for the past 10 years. I ran stock with 32s until I was able to finally afford what I wanted to do. Here is the jeep before I did anything to it. ![]() 1st thing I did was put a 4.5 inch RE lift on it and some 35’s. Then I swaped out the d35 for a f8.8 with a detroit and I put an arb into the dana 30 All a big waste of $$$. Ran it like this for a bit.
93 yj with a hard top and some other stuff [url]http://pirate4x4.com/forum/showthread.php?t=649135[/url] |
Member # 84246
Decided I wanted a cage so talked to a few local guys and bought a bender, bend tech ez 3d and a notcher.
My 1st job with the bender ![]() ![]() ![]() ![]() ![]() ![]() Pulled it all out and welded it up. Back in and painted.![]() Cage done for now.
Member # 84246
Jeep did ok as it was but was figuring out that I wanted to go bigger!
At FordyceCame across a pretty good deal on some axles. ![]() Didn’t know what I wanted to do with them. Put them on the current ride or start a new one? The mogs sat in the yard for a few months while I thought about what do do with them.
Member # 84246
Breaking the dana 30 going down hill helped me figure out what I was gonna do with the mogs real quick.
![]() ![]() If you’re running the dana 30 a spare shaft isn’t enough cary upper and lower ball joints… This thing broke way to easy, oh well live and learn…
Member # 84246
Parked the jeep, started buying parts, and sold the small stuff
Plans are. 404’s Disc brake conversion from Exaxt H2 wheels with beadlocks from Champion wheel 42 inch Iroks 3 link- rear 3 link with panhard- front Coilovers front and rear Full hydro AW4 with Aw shift controller Gen Right Protection. Already had the tera 4-1 in the np-231 and sye kit, so gonna run that as long as I can.
Member # 84246
The Exaxt disc brake conv. Couldn’t be any easier (after buying a HF press).
Conv. kit Portal removed 404 shaft![]() ![]() Portal housing on the bench with the hub (now garbage) and main gear removed. The new hup put together. New hub with studs and caliper brackets bolted on. F350 calipers and rotors. H2 wheels on.
Member # 84246
Got anxious and put just the tires under it. I wish I could get it this low. This will probably be how it sits full stuff.
![]() ![]() I got kicked by a horse last week and had to get some screws and plates put in my arm. So I’ll be down for a few weeks to let it heel. Got most the parts on order to finish this thing and they should be here by the end of next week. This is my 1st build, being done by asking a lot of questions and buying a red star. All help and comments are appreciated. Ill update as soon as the arm is good to go.
Member # 103613
Jeep build
Looks Good!
Check out kebmre and atkins4x4 on you tube. <BR>88 wrangler d60 front 14 bolt rear currently getting 375hp 350 sm465 231/300 doubler 106"wb 42" LTB's Built not bought, First build. |
Trapped in the 80's
Member # 70340
Just subscribed to to your thread.. interesting.
TRADES: Want: GoPro Hero3, new iPad 3G, Galaxy Note II Have: VANCO Hydrobooster, ORO Swaybar, Robby Gordon and Walker Evan 17 Beadlocks, Swing-Out tire carriers, 2.5 Fox Bumps, TJ Windshields/Half Doors, HP D60 w/ARB-4.56, 14Bolt w/Detroit-4.56 |
#13 (permalink) |
Member # 84246
Right now the GOAL is to get the wb somwhere around 110" and Would like to keep the the top of cage under 87". Gonna be tough to keep it low.
#14 (permalink) |
Nice Chris, I'll have to pop on by the house and check out the project since I havent seen it since you broke that dana 30
![]() ![]() ![]() ![]() ![]() Im headed out to Shawns house to continue finishing up my dana 60/70 so I can get them slapped under my rig. This spring and summer should be a good one
#16 (permalink) |
Member # 41708
Ground Clearance!!!!
ECV - 1852 '56 CJ6 - 4.3, 904, D300 w4:1, 60/70, 5.38's, 35spline chromo, 42" IROKS....family crawler '71 Chevy 4x4, built 502, 1 tons and 40's G-Man Racing #213 - LQ9, 400, 4sp Atlas, 70/14B, 5.13's 39 BFG's....2013 LCQ we are going to give it all we have!!! |
#18 (permalink) |
Trapped in the 80's
Member # 70340
Read again:
That's a good question..
#20 (permalink) | |
Member # 84246
front wms-wms 69" rear wms-wms 68 Disc brake from Exaxt front 77" Rear 76" Info here http://www.exaxt.ca/axle.asp Dont know the #'s on the 60/14b setup and somone else can probably give it faster than I can search for it.
#21 (permalink) |
Newbie
Member # 101865
Front 60s are typically 69"
14 Bolts are typically 67"
'88 YJ one tons soon ... already have a KP/HP D60 , 14b and five H2 wheels 4.2 / H.0. head / Howell TBI / HEI / (ext. slave) AX-15 / Warn X8000i on an ARB Bullbar / 33" BFG Mud Terrains / D30/8.8LSD 4.10 |
#23 (permalink) |
believe nothing i sa
Member # 17121
depending on where you muont the uppers mounts for the coilovers, you shouldn't have much of a problem keeping your height you want, you'll just have hoops sticking through the hood, which is always cool. i'm at 110'' and at about 83'' or so to the top of the cage, i can fit through a standard garage door easily. i could have lowered it quite a bit if i would have gone with a 3 link instead of the double triangulated 4 link up front.
here's what mine looked like before it was done (only good side pic of it).
if you can't make it, get red labels. |
#24 (permalink) | |
Member # 84246
#25 (permalink) |
Member # 17121
the mogs are the only reason i would think you would have to run them through the hood, as long as you don't go crazy long on the coilover, keep it to like a 12'' or so, and you'll be fine.
