5.2l swap into a cj. can i use a dana 300? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-31-2008, 05:00 AM   #1 (permalink)
Member # 107610
I have a 96 5.2l v8 with auto and od out of a grand. I plan to swap them into my cj6. wondering if there are any adapters to mate a 300 to that trany, or if a dana 300 will bolt up at all. any help? Or would it be easier to just go with a 4.0l?
fiseboy458 is offline   Reply With Quote
Old 01-31-2008, 07:14 AM   #2 (permalink)
Member # 20092
it should bolt right up. The D300 shares the same bolt pattern as the original np t-case in the donor vehicle. Just check the output shaft on the transmission to ensure that it is 23 spline, and that it is flush with the t-case adpater mounting surface. If it sticks out, then you may need a spacer from advanced adapters.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
Old 01-31-2008, 08:20 PM   #3 (permalink)
the freeak's Avatar
Member # 41185
If you need that spacer I have one for sale...with new longer input shaft and clocking ring... /hi jack off/
the freeak is offline   Reply With Quote
Old 02-01-2008, 09:38 AM   #4 (permalink)
Member # 21146
yes you will need to run an adapter/ spacer. i put a pass drop d300 in my grand and i used a go2guy clocking ring,about 5/8 thick and still needed more room. advanced adapters did not have that adapter out at the time i installed my tcase. it should be thick enought that no mods will have to be made. if i remember right , its been a couple years, it was something like 7/8 of an inch you will need to make up or the output of the trans will bottom out in the tcase before it mates up to it. i modded my bearing retainer with a different seal location and turned the input shaft down to accept a seal futher int he tcase.
edit: mine is also a 96 v8 5.2. it should have the long output shaft. i think there was 2 different length 23 spl outputs, or maybe it was a 21 and 23 spl hell i cant remember that was to many brain cells back.
TexasBlake
PBB was more fun when the righty-tighties were in office. Now it's just a whine fest.
speedmontzj is offline   Reply With Quote
