Turbo Jeep guys.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-19-2008, 09:35 PM   #1 (permalink)
Member # 108575
Turbo Jeep guys....
I just installed a T3/t4 on my 1995 2.5L YJ. I am not sure if I need to pull timing out or if I will be ok just running 93-94 octane pump gas with about 7 psi.
What do you guys do for a timing retard? Everything I read says that ignition timing is not adjustable, but there has got to be a way to do it. I guess I could use an MSD box with a BTM, but MSD's don't like to get wet.
Thanks!
Rob the plumber is offline   Reply With Quote
Old 02-19-2008, 09:54 PM   #2 (permalink)
Member # 61182
Send a message via AIM to LumberJack5500
3....2.....1....
http://www.pirate4x4.com/forum/showthread.php?t=625936
LumberJack5500 is offline   Reply With Quote
Old 02-19-2008, 10:06 PM   #3 (permalink)
Member # 24496
You need to pull timing under boost, and you need to get more fuel.
The proper way to do it would be to ditch all the factory computer stuff and run something like megasquirt, but I'm not up to speed on how or if people are doing it with the 2.5L sensors, or if it's even doable. You could probably get away with running a rising rate or adjustable fuel pressure regulator and some bigger injectors, but it won't be totally fine tune-able.
The MSD box coupled with the MSD boost timing master is a good way to go.
Really, if you want the motor to last and perform the best, you should have it professionally tuned. If you just want to make sure it's not going to grenade the first few trips out, get some more fuel in and get some timing out when in boost.
For reference, I ran a turbocharged D16Z6 in a Honda Civic for autocrossing for a few years. It was a fun little car. I ran an MSD w/BTM, and a Apex'i VAFC fuel controller with 450cc injectors from a mitsubishi eclipse. It ran ok, but it was no aftermarket fuel management a'la Hondata or AEM.
NotMatt is offline   Reply With Quote
Old 02-20-2008, 08:16 AM   #4 (permalink)
Member # 108575
I am using a 12 to 1 FMU which should be on par for my 19lb Ford injectors, along with a 255lph pump. I thought maybe I could elongate the holes for the crank sensor to pull out a couple degrees. That would probably change injector timing as well though right?
I don't know anyone in my area (Detroit 'burbs) that tunes Jeep stuff. I don't need it to be tuned for absolute power, but just to keep it alive with a decently rich A/F ratio under boost.
Old 02-20-2008, 09:34 AM   #5 (permalink)
Member # 7102
Hey Rob,
You can adjust the timing a little bit by slotting the CPS like what Turbo City did.
jeffy is offline   Reply With Quote
Old 02-20-2008, 09:27 PM   #6 (permalink)
Member # 108575
Thanks, i'll have to give that a shot.
Old 02-20-2008, 09:44 PM   #7 (permalink)
My1stNiceJeep's Avatar
Member # 65637
Originally Posted by LumberJack5500 View Post
3....2.....1....
BACKFIRE
Isnt there a Lag issue using a turbo?I was under the impression that it shocked most of the drivetrain parts when it did spool up.Thats from reading here and there so its not firsthand.Did the search yeild any relavant info?
My1stNiceJeep is offline   Reply With Quote
Old 02-20-2008, 09:59 PM   #8 (permalink)
Member # 108575
I came up with nothing using the search. Most people say "Just run a stand alone like Megasquirt". This is a low budget project just to see if I could do it.
Boost does not shock anything. It comes on nice and smooth, just off idle. Lag does not seem to be an issue for me.
Old 02-20-2008, 10:06 PM   #9 (permalink)
Member # 65637
Cool I like low budget anything.I have read quite a few rightups with turbo and supercharging but yet to attempt any.But I keep reading and when shit falls in my lap Ill attempt it.But until then I keep reading.Let us know when you get it worked out.BTW The backfire wasnt for you is for post # 2 Good luck
Old 02-21-2008, 12:49 PM   #10 (permalink)
Member # 14139
do you have the part # on the colder plugs that your running?
wckdyj is offline   Reply With Quote
Old 02-21-2008, 12:57 PM   #11 (permalink)
Member # 47730
Thanks!
show the pictures of your setup.i saw them on greatlakes4x4.com.nice work.
a bunch of tube.a v8 and other stuff..
2nuts4u is offline   Reply With Quote
Old 02-21-2008, 01:03 PM   #12 (permalink)
Member # 83979
I would also install an Air/Fuel ratio gauge. That way you can keep an eye on things,especially under boost. You don't want that little sucker foing way lean on you. It willl also hep you tune it easier.
Project po-boy is in effect- cause I'm poor!
http://www.pirate4x4.com/forum/showthread.php?t=663656
BULLET99Z28 is offline   Reply With Quote
Old 02-21-2008, 01:06 PM   #13 (permalink)
Archimedean
rustywagoneersdotcom's Avatar
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
Page 4 right now.
/forum/jeep-hardcore-tech/649011-turbo-thread.html
Someone sort of local sell me a Dodge NP435, or the mainshaft/tailhousing from one.
Or, sell me a Ford NP208 input gear...
rustywagoneersdotcom is offline   Reply With Quote
Old 02-21-2008, 01:09 PM   #14 (permalink)
Archimedean
Member # 65100
another recent one
/forum/jeep-hardcore-tech/614289-400hp-pump-gas-friendly-4-5l-stroker.html
Old 02-21-2008, 01:11 PM   #15 (permalink)
Archimedean
Member # 65100
another
/forum/general-4x4-discussion/651385-how-come-no-one-turbo-charges-v8s.html
Go to google.
Go to advanced search.
Type your keyword. (turbocharge, turbocharger, turbocharged, turbocharging)
Narrow it to the site you think will help the most.
Then google search for terms like 'junkyard turbo' etc.
