Back Half Inspiration Thread - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-18-2012, 09:13 PM   #126 (permalink)
rockwellyj's Avatar
Member # 148940
Anyone seen a backhalfed 4-door yet? I want to do it to mine something fierce.....
Just don't want to F-up and make it look like bawls....
YJ buggy
2012 6.7 3500
rockwellyj is offline   Reply With Quote
Old 04-19-2012, 04:02 AM   #127 (permalink)
Member # 23452
Then,
Now
Jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote
Old 04-19-2012, 12:25 PM   #128 (permalink)
rockwellyj's Avatar
Member # 148940
What rearend is that? Or front?
YJ buggy
2012 6.7 3500
Old 04-19-2012, 12:28 PM   #129 (permalink)
Member # 127171
Chebby Dana 60 front.
"You never really know a woman until you meet her in court!"
sleepsontoilet is offline   Reply With Quote
Old 04-19-2012, 01:26 PM   #130 (permalink)
rockwellyj's Avatar
Member # 148940
guess I could have looked a little closer at the kingpins! How's it hold up as a rear?
YJ buggy
2012 6.7 3500
Old 04-19-2012, 08:21 PM   #131 (permalink)
Member # 23452
Just rolled it out this week. But several have done it along with a few friends and it works perfect. A little offset to the driver side but for a low speed crawler it will be fine.
Jason.
Old 05-20-2012, 09:23 AM   #132 (permalink)
rockwellyj's Avatar
Member # 148940
YJ buggy
2012 6.7 3500
Old 05-20-2012, 02:15 PM   #133 (permalink)
rockwellyj's Avatar
Member # 148940
YJ buggy
2012 6.7 3500
Old 05-20-2012, 08:30 PM   #134 (permalink)
Member # 99088
My JUNK
rocksand is offline   Reply With Quote
Old 05-20-2012, 08:35 PM   #135 (permalink)
Member # 99088
Old 05-24-2012, 07:33 AM   #136 (permalink)
Member # 74101
Send a message via Yahoo to rockinjeep
Nice stance! What is you wheelbase at? You got anymore pics.
I'm fixing to Juggy my Yj and am looking for some good ideas.
Thanks
Mike-
4 wheel it like you stole it
Almost a human again!
rockymountainextreme.com
texas4x4.org
My build-up thread:
[url]http://www.pirate4x4.com/forum/showthread.php?t=630979[/url]
rockinjeep is offline   Reply With Quote
Old 05-24-2012, 07:35 AM   #137 (permalink)
TN-D90's Avatar
Member # 85510
guy in my club just finished this, it's pretty badass. Frame is cut off right around the seats. Entire cage is removable also
1989 YJ- Vanilla Ice motor,c4,atlas 5.0, 4linked, 60/14b
www.Dixiecrawlers.com
TN-D90 is offline   Reply With Quote
Old 05-24-2012, 11:57 AM   #138 (permalink)
Rugger99's Avatar
Member # 22646
Mine...
" Never underestimate the power of idiots in large groups"
Rugger99 is offline   Reply With Quote
Old 05-29-2012, 07:50 AM   #139 (permalink)
rockwellyj's Avatar
Member # 148940
Thanks
Mike-
Thanks man. I've got it at 116" right now. I like how it turned out so far. The tub and frame in the rear was trashed so this was the best way to fix that!
I used a peice of 2x4 1/4" wall above the frame for a cage tie in. I still lack the extra gusseting but hope this week I'll be done with that part. Then mount some shocks, fuel cell, wiring, rear disk. The list keeps going.
YJ buggy
2012 6.7 3500
Old 05-29-2012, 11:17 AM   #140 (permalink)
rockwellyj's Avatar
Member # 148940
Originally Posted by Rugger99 View Post
Mine...
Clean
YJ buggy
2012 6.7 3500
Old 05-29-2012, 08:04 PM   #141 (permalink)
Member # 74101
[QUOTE=rockwellyj;14410714]Thanks man. I've got it at 116" right now. I like how it turned out so far. The tub and frame in the rear was trashed so this was the best way to fix that!
Yeah I suffer from the same thing. How did you mount you upper, lower links to the frame with the square tubing running arcoss the frame? I would like to do the same thing, but I want to use ruff stuff brackets and need the frame rail to mount them too. It seems that the upper link woukld hit the square tubing too early in the suspension cycle.
Thanks for the reply
Mike
Edit: Just noticed that you ran the 2x4 on top of the frame so I guess the upper links would have alot of room throughout the whole cycle.
texas4x4.org
My build-up thread:
Old 05-30-2012, 08:36 PM   #142 (permalink)
rockwellyj's Avatar
Member # 148940
[QUOTE=rockinjeep;14413295]
Mike
I'm between ideas right now but currently I have some ballistic frame brackets for the lower links. Just welding them onto the bottom of the frame with some extra plating so I don't rip out a chunk of the frame.
YJ buggy
2012 6.7 3500
Old 06-27-2012, 12:06 PM   #143 (permalink)
Member # 127171
Progress as of lunch. I got the lower backhalf complete, and Artec cell mount welded in solid. Did the two bars of lacing behind the seat, still have to do the outer two and the bars below where they tie in. That way it isn't a dead node. Thinking of trying to find a way to tie that bar into the frame as another structural tie in
Opinions welcome
Old 06-27-2012, 08:30 PM   #144 (permalink)
rockwellyj's Avatar
Member # 148940
Guess I will post a bit of progress. Got shocks in finally
I need to do some reworking to mount my airshocks. Need to in lard the top and build a tower to raise my top mount. 16s are longer than I thought.
YJ buggy
2012 6.7 3500
Old 06-28-2012, 05:52 AM   #145 (permalink)
vogelj's Avatar
Member # 49483
Opinions welcome
When are you going to start a build thread on Pirate?
Tellico Rally Post - 312
vogelj is online now   Reply With Quote
Old 06-28-2012, 03:11 PM   #146 (permalink)
Member # 127171
It's not really all that hardcore or fancy, hadn't thought much about it bud.
Didn't like the visibility being blocked by the poly performance kits dash bar, so I cut it out and threw it in the scrap pile. Since I can't really reuse the stock yj gauges, and the wiring harness was cut to pieces, I went ahead and scrapped it as well. Gonna try my hand at a simple flat dash. Added some console bars while I was at it, to mount the Art Carr shifter to. Got the bars from A pillar to the firewall tacked on as well. Then I pulled the cage to finish welding the underside.
I need some suggestions on the door bars. I really like the stock modified setups I've been seeing. Also like the simple bent hip bars. Just not sure which route to go.
Todays progress:
Old 06-29-2012, 07:24 AM   #147 (permalink)
vogelj's Avatar
Member # 49483
This is kind of what I was thinking on mine. I know it will be a pain to get in and out but I like the idea of being contained if I go over.
Old 06-29-2012, 08:30 AM   #148 (permalink)
tjjared413's Avatar
Member # 46942
very nice!
making notes maybe doing this over the winter..
04tj with round tires
04 d-max tow rig
tjjared413 is offline   Reply With Quote
Old 06-29-2012, 12:21 PM   #149 (permalink)
Member # 127171
If you look at Dirt Fab's build for broadsword that's how he did them. I like it a lot as well. Also like how HOFF did DJ's bars.
Old 06-29-2012, 07:54 PM   #150 (permalink)
tlshep89's Avatar
Member # 154343
Here is a friend of mines, Jason Vanovers, cage. Thought it turned out really good.
Visit us at bigsouthforkoffroad.com
tlshep89 is offline   Reply With Quote
