Dana 60 Rear Truss...how Thick - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2008, 04:58 AM   #1 (permalink)
Member # 43296
Looking to Fab up a Simple bridge type truss on my rear 60 to tri link it in my TJ...
How thick???? 1/2 3/8 ????? any pics for idea welcome....
CJ5350 is offline   Reply With Quote
Old 03-12-2008, 05:09 AM   #2 (permalink)
Member # 106059
I used 3/8" flat stock 4" wide. Used a torch and a vice to get the necessary bends I wanted. Turned out nice.
1998 TJ, GM 350TBI, TH350, Dana 300, Dana 60's,5.38's,spooled, linked on 42's
1998 2500 4x4 Chevy, 454, 4L80E, 4.10s, tow rig
2002 Ford Excursion Limited 4X4 7.3L PSD, grocery getter/tow rig
5540jd is offline   Reply With Quote
Old 03-12-2008, 03:18 PM   #3 (permalink)
Member # 97644
i used 1/2 "...................no problems.better to go a little overkill on a truss if your on the fence about it.
t.j.,tons,116",full hydro,40"creepys....... short fingers
txdave is offline   Reply With Quote
Old 03-12-2008, 03:34 PM   #4 (permalink)
rokcrwlrtj's Avatar
Member # 27180
Send a message via AIM to rokcrwlrtj
2x4 box 1/4" wall on mine.
Save Tellico Post 296
rokcrwlrtj is offline   Reply With Quote
Old 03-12-2008, 03:41 PM   #5 (permalink)
Member # 107843
Send a message via MSN to Bump&Grind
go as thick as you can. It's the same effort to bend 1/2 as 3/8 in a vice with a torch. Might as well go beefy, the added insurance is good. Besides thicker material take stress better over the long run.
Bump&Grind is offline   Reply With Quote
Old 03-12-2008, 07:27 PM   #6 (permalink)
Life on the Darkside
Brink_'s Avatar
Member # 63901
I use 2x3 box .250 wall. Mitered and welded....never had a problem. Seen lots of heated and bent style ones end up tearing at the bend though.
Brink_ is offline   Reply With Quote
Old 03-12-2008, 08:18 PM   #7 (permalink)
Member # 70814
Send a message via AIM to LS1Jeeper
Mine is made from 1/4" thick material, with some 1/8" gusset for some extra strength.
:shaking:
LS1Jeeper is offline   Reply With Quote
Old 03-12-2008, 08:29 PM   #8 (permalink)
Member # 55362
Did mine out of 1/2x4 flatbar. Bent in our 10' sheetmetal brake.
East Coast Buildup: [url]http://www.pirate4x4.com/forum/showthread.php?t=597717[/url]
Acts 20:24
hardline04 is offline   Reply With Quote
Old 03-13-2008, 02:45 AM   #9 (permalink)
Member # 43296
1/2 4' flat bar it is...thanks guys
Old 03-13-2008, 06:25 AM   #10 (permalink)
Member # 80590
just finished up mine. the main plate going over the housing is 1/2 inch thick. and then the truss is braced front and back with 3/8 inch steel
intheworks is offline   Reply With Quote
