CJ-5 Monster rebuild.. - Page 9 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2008, 12:14 PM   #201 (permalink)
Member # 66838
Great deal !
JT Automotive & Off Road
Harrison AR
Shop 870 743 3188
Cell 870 688 3954
Here's a link to our rig(Project Blue Bitch)
[url]http://www.pirate4x4.com/forum/showthread.php?t=808501&highlight=project+blue+bitch[/url]
katesoffspring is offline   Reply With Quote
Old 11-16-2008, 01:57 PM   #202 (permalink)
Member # 101253
Originally Posted by katesoffspring View Post
Great deal !
Yea i went and wheeled over in joshs ditch for a little while today and it does alot better with those tires than with the 38's. but i only had about 7lbs of air in the 42's and i run about 18-20 in the 38's. But i think they were a great deal..
81 CJ-7 38.5 TSLS
Cj-5 Monster Rebuild
chevyman12212007 is offline   Reply With Quote
Old 11-16-2008, 03:26 PM   #203 (permalink)
Member # 119659
i see a lot of fender well trimming, front flat fender, and dove tail in the rear in your future. nice score
btw i want your fender flares when you do.
last boyscout is offline   Reply With Quote
Old 11-16-2008, 08:02 PM   #204 (permalink)
Member # 101253
Gotta have some bigger axles for those meats before i can do much of anything. i dont think 1/2 ton chevys are goona hold
81 CJ-7 38.5 TSLS
Old 11-18-2008, 02:11 PM   #205 (permalink)
Tinkerer
oldtimingman's Avatar
Member # 75774
Originally Posted by cherokeefreak92 View Post
Those dont even look worth having. They look so bad.
Get a grooving iron and those tires will come alive!
oldtimingman is offline   Reply With Quote
Old 11-18-2008, 03:44 PM   #206 (permalink)
Member # 101253
they have already been groved to hell! the cords are showing in some places but i do plan to grove them some more.
81 CJ-7 38.5 TSLS
Old 11-18-2008, 05:15 PM   #207 (permalink)
Member # 101253
Have a few new updates,, He got his front axle all painted up and is now ready to be put together.. Also got the tie rods and skid palte for the ram painted..
81 CJ-7 38.5 TSLS
Old 11-20-2008, 11:30 AM   #208 (permalink)
Member # 119997
Looks good. You need to bring that thing down to rsvl next time you feel like hauling something and we'll go ride around... assuming mine ever starts again. but again good go'n get'n those
You build it, I break it :nuke:
cjcustomx is offline   Reply With Quote
Old 11-20-2008, 11:33 AM   #209 (permalink)
willhf1011's Avatar
Member # 108095
you guys have made some relatively quick progress for building the rig from the frame up. sweet build keep em coming
willhf1011 is offline   Reply With Quote
Old 11-20-2008, 08:17 PM   #210 (permalink)
Member # 101253
Well this build has been going for a few months more than the thread has been around..
81 CJ-7 38.5 TSLS
Old 12-01-2008, 08:37 PM   #211 (permalink)
Member # 101253
M35a2
Any of you guys know of a good place to buy a complete running 2 1/2 ton or 5 ton truck? Military surplus or something??
81 CJ-7 38.5 TSLS
Old 12-02-2008, 03:35 PM   #212 (permalink)
Member # 119659
right here on pirate
/forum/miscellaneous/737968-military-6x6-deuce-very-nice-3500-a.html
Old 12-21-2008, 11:23 AM   #213 (permalink)
Dudewayne's Avatar
Member # 125011
subscribed ! Excellent Build
Dudewayne is offline   Reply With Quote
Old 12-29-2008, 06:45 PM   #214 (permalink)
Member # 101253
ok guys its been a while we have all been busy with other things but i have got some updates for you..
Battery box has been fabbed up and mounted
radiator and gril have been fitted
brakes are now 90% complete
shifter hole has been enlarged to allow for full range movement
Front axle now has a detroit and new axle u-joints, rotors have been turned, need to install new seals and pack the bearings.
steering is mounted and high steer arms installed
new RCI fuel cell
And here is my latest project, one of the reasons i havent been keeping up with the updates on here..
81 CJ-7 38.5 TSLS
Old 01-03-2009, 09:03 PM   #215 (permalink)
Member # 101253
Updates
Hey guys i have a few more small updates for you..
Today we fabbed up a fuel cell mount
we started with some 1 1/2 x 1 1/2 angle iron to make the frame...
and then we made some tabs for the straps and mounting the frame...
Then we cut the straps to length and started bending..
Test fit of the straps and tabs..
81 CJ-7 38.5 TSLS
Old 01-06-2009, 09:01 PM   #216 (permalink)
Member # 101253
Got the fuel cell mount all welded up and ground smooth, painted it this afternoon. Should have it back in the jeep tomorrow. The front axle is assembled now. I didnt get a pic of that for you guys but its looking pretty good now. Next step will be triming the cowl to allow the hood to open and then some final welding on the firewall. Pretty soon Josh will be ordering a set of corbeau seats for driver and passenger. thats all the updates for now..
81 CJ-7 38.5 TSLS
Old 01-06-2009, 11:47 PM   #217 (permalink)
Member # 125659
sweet build! looking good...
Big_Red1tonJeep is offline   Reply With Quote
Old 01-07-2009, 08:50 PM   #218 (permalink)
Member # 101253
Thanks man!
81 CJ-7 38.5 TSLS
Old 01-07-2009, 09:06 PM   #219 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
Did you put anything between the straps/base and the alum. tank? I was just curious if it would rub after a while and cause a problem? Build looks good btw
mudskipper4x4 is offline   Reply With Quote
Old 01-07-2009, 09:10 PM   #220 (permalink)
Member # 101253
Havent installed the tank just yet, but ya we have some rubber strips that will go around the base and under the tank straps, should keep it from rubbing anywhere.. i will have some more pictures some time that will show how we did it
81 CJ-7 38.5 TSLS
Old 01-07-2009, 10:23 PM   #221 (permalink)
Member # 51866
Thumbs up
subscribed, nice build.
jeep_unlimited is offline   Reply With Quote
Old 01-08-2009, 11:26 AM   #222 (permalink)
AllUpInYourFace
Member # 72951
Sounds good to me... I was wanting some ideas on a good way to mount the exact same tank in my rig. I may have to copy
Old 01-08-2009, 01:30 PM   #223 (permalink)
Member # 115235
1970-1973 Camaro?
2008 Jeep JKU Rubicon
SOLD - (1988 Jeep YJ/CJ and 1994 Jeep YJ)
Piet is offline   Reply With Quote
Old 01-08-2009, 05:53 PM   #224 (permalink)
Member # 101253
Piet,
I wish it was, but its an 81 Z28.. we are transplanting an alum headed LT1 from a 95 cop car at the moment..
81 CJ-7 38.5 TSLS
Old 01-09-2009, 06:30 AM   #225 (permalink)
Member # 85980
Add me to the list of "That's lookin pretty fuckin good" posts.
There's a lot more people on here from Harrison on here than I expected.
glock30 is offline   Reply With Quote
