16.5" rims... no safety bead?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2002, 05:28 PM   #1 (permalink)
Member # 7914
Send a message via AIM to FireTruck
I have been looking for some 16.5" rims for my 8 lug D60 transplant for my TJ...
It would seem that NO 16.5" rims have a safety bead - is this correct? It is not an issue if you are beadlocking them, and I am putting internal beadlocks into 4 of them (tyrelocks).
But what about the 5th? I am getting mixed feedback - yes, you can run them tubeless... no you can't and you will need a tube.
Not sure what my chances are of finding a tube... running 38.5x14.5-R16.5 TSL SX's.
Anyone running 16.5" tubeless? DO they have a safety bead? Just wondering if I have to drop another AU$320 into a 5th beadlock for the spare.
Team #197, WE Rock and OZ Rock Aussie series.
FireTruck is offline   Reply With Quote Quick reply to this message
Old 07-15-2002, 05:32 PM   #2 (permalink)
Member # 12152
16.5 rims do not have a safety bead, but depending on the tire, they can be run without a tube, just not at very low pressure without risking blowing a bead. It's not that hard to grind the Dana 60 calipers down to clear 16" or 15" rims but it sounds like you've already invested quite a bit of time and money into 16.5's
'46 CJ-2A, '47 CJ-2A, '48 CJ-2A, '50 M38, '52 M38A1, '62 CJ-3B, '62 CJ-5, '65 CJ-5, (2) '66 CJ-5's, '67 CJ-5, '69 CJ-5, '69 J-3000, '70 CJ-101, '74 DJ-5, '74 CJ-5, '77 CJ-5, '78 CJ-5, '78 CJ-7, '78 Wagoneer, '95 YJ, '97 XJ...None of them run.
4Bangler is offline   Reply With Quote Quick reply to this message
Old 07-15-2002, 05:50 PM   #3 (permalink)
Member # 7914
Yup - not real keen on grinding enough to fit a 15" rim, and the tire size options for 16" rims are very limited (big swampers etc. I mean)... hence the 16.5's.
As a spare I guess it would be ok tubeless, as long as I don't drop the pressure too much... how far is too much on these rims??
Old 07-15-2002, 05:55 PM   #4 (permalink)
Member # 940
As long as you keep some good pressure in them they will work. They do not have the safety bead or at least not much of one unless you go with Hummer wheels. They are 16.5.
You can get the thornbirds in a 38.5X14.5X16 or just get 15" wheels that have 2.5" backspacing and then no grinding required!
Deep Cryogenic Tempering Service
Find all my products at
916-434-6978
Custom Sway Bars and Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote Quick reply to this message
Old 07-16-2002, 05:23 PM   #5 (permalink)
Member # 3547
my question is why??
Wjy why why do 16.5" rims not have a safet bead? What was the manu's reason for this??
never understood it
BillaVista is offline   Reply With Quote Quick reply to this message
Old 07-16-2002, 05:37 PM   #6 (permalink)
Member # 12152
Grinding to clear 15" rims isn't really that bad, but here's an example of a 16.5 tire at 10psi, of course it's a 39.5x18 Mickey Junkson on a 16.5 x stupid 14" rim, and the guys drives like a tool, whoops, his brother hangs out on this board, aw hell, he knows his brother drives like a tool.
16.5's lack of a safety bead also means it's super easy to blow the bead completely over the rim, or have the fire suck the tire back off the rim really quickly. PITA to say the least. By the way, who would ever buy Thornturds?
Old 07-16-2002, 10:00 PM   #7 (permalink)
Brian1's Avatar
Member # 2205
check it out - http://www.tennessee4x4.com/toyota/1...fety_beads.htm
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote Quick reply to this message
Old 07-16-2002, 11:05 PM   #8 (permalink)
Member # 9230
Around here the I5 four wheel drive crowd swears by Thornbirds.
I think they like the look after 10 k of pavment driving. The center of the tire wears smooth so it looks like a racing slick with nobbies.
Panties aren't the Greatest thing in the World but they're right next to it.
Bonestripper is offline   Reply With Quote Quick reply to this message
Old 07-16-2002, 11:19 PM   #9 (permalink)
Member # 3906
Send a message via AIM to Jeepmangled87
get some hummer bead locks, they are 16.5 beadlocked and cheaper than any other beadlocked wheel.
Jeepmangled87 is offline   Reply With Quote Quick reply to this message
Old 07-17-2002, 02:00 AM   #10 (permalink)
Member # 7914
Thornturds... ummmmm, no thanks.
Hummer wheels may work, but harder to get here and probably not road legal in Australia... not that a 38.5" SX is road legal either, but one less reason for the fuzz to pull me over. Crazy backspacing too, but not too hard to fix.
External (mechanical) beadlocks aren't legal either, which is why I am going for internals this time... not that I have had any hassles with my 15x8" external beadlocks yet - just figured that if I had the chance I would go for the internals. Axel swap is the perfect excuse
Old 02-01-2009, 03:57 PM   #11 (permalink)
ahighfivetolife's Avatar
Member # 70117
This guy!
He does it for the ladies. People who are totally noob to wheelin think that these and boggers are the coolest damn thing ever.
'73 K5 350/TH350/NP203/14B/D60/5.38/SPOOLED/42's
ahighfivetolife is offline   Reply With Quote Quick reply to this message
Old 02-01-2009, 04:04 PM   #12 (permalink)
xjtony's Avatar
Member # 50866
or a guy that would bring a thread back to life after almost 7 years....
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 04:23 AM   #13 (permalink)
Member # 2790
never understood it
because the 16.5 were "truck" rims and at normal truck pressures (60+ psi)there is no issue with the bead coming off. Also when they were made pick ups (trucks) were not a the cool vehicle to have and went mostly to businesses and farmers, who were more likely to maintain there tires.
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 06:53 AM   #14 (permalink)
Member # 70117
Damn straight. That's how I roll.
Old 02-02-2009, 10:54 AM   #15 (permalink)
Member # 62972
I wouldn't say all 16.5 rims don't have a saftey bead. Out of the 4 rims I have, 2 of them do.
JCM
madisonjam85 is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 12:24 PM   #16 (permalink)
Member # 83301
since we brought back the super old thread...anyone here ever weld 1/4 rod the whole way around the inner bead to help hold it on. a guy i know uses it with the inner bead and has the outer bead locked?
Old 02-04-2009, 01:22 PM   #17 (permalink)
Member # 116883
Check this out,
http://www.4x4spot.com/16_5_rims_and_safety_beads.htm
Mr. Pickle is offline   Reply With Quote Quick reply to this message
Old 02-04-2009, 02:53 PM   #18 (permalink)
Moderator
geberhard's Avatar
Member # 5861
holly f... talik about an old thread being ressurected. BTW there is another 5 years old threda that has pictures of welding the rod across the wheel for a safety bead. As it was said even back then, search fawker
geberhard is offline   Reply With Quote Quick reply to this message
Old 02-04-2009, 04:20 PM   #19 (permalink)
88flexj's Avatar
Member # 56895
1/4inch would be a bitch to get the tire over. I used 3/16 round stock tack welded every 1/2 inch, and ramped the inside edge with body filler. Sand it smooth and the tire slides right over it. I just hope I dont have to take it off anytime soon.
[COLOR="darkorange"][/COLOR]Santa Cruz 4 Wheel Drive Club
88flexj is offline   Reply With Quote Quick reply to this message
Old 02-04-2009, 05:19 PM   #20 (permalink)
Member # 83301
then link it up haha
Old 02-04-2009, 05:53 PM   #21 (permalink)
Member # 83301
http://www.pirate4x4.com/forum/showt...ht=safety+bead
