which springs should I try? - Pirate4x4.Com : 4x4 and Off-Road Forum
View Poll Results: which springs should I try on my YJ?
4" Waggy BDS springs that would give maybe 5.5" lift (450 lbs/in) 1 8.33%
4" Waggy Rusty's spring that would give maybe 5.5" lift (310 lbs./in 0 0%
2.5" Waggy Rancho 44044 springs what would give maybe 4" lift (300 lbs./in) 4 33.33%
3.5" YJ BDS springs (325lbs./in) (people say they get at least 4" from it) 1 8.33%
none of the above 6 50.00%
Voters: 12. You may not vote on this poll
Old 08-03-2002, 06:45 PM   #1 (permalink)
Member # 12878
Send a message via AIM to Taso Stambolis
Smile which springs should I try?
4" front Waggy BDS springs that would give maybe 5.5" lift (450 lbs/in)
4" front Waggy Rusty's spring that would give maybe 5.5" lift (310 lbs./in)
2.5" front Waggy Rancho 44044 springs what would give maybe 4" lift (300 lbs./in)
none of the above
Taso Stambolis is offline   Reply With Quote Quick reply to this message
Old 08-03-2002, 07:02 PM   #2 (permalink)
Member # 4001
Were you going to include other info about WTF there are going on? (I know it's a YJ...but we need a lot more info)
Scout Dude is online now   Reply With Quote Quick reply to this message
Old 08-03-2002, 08:07 PM   #3 (permalink)
Member # 12878
Doh, sorry. '89 YJ in SUA form. Right now i have no suspension lift, TJ flares, 1" BL, and 31" BFGs. 3.55/3.54 gears with posi in the back. 5 speed 4.2L.
Old 08-04-2002, 08:29 AM   #4 (permalink)
B.A.R.K's Avatar
Member # 8540
where is the selection for SOA, that is the only lift you should be thinking about, the others are just a waste of money
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 08-04-2002, 10:10 AM   #5 (permalink)
Member # 12878
then pick none of the above
Old 08-04-2002, 10:37 AM   #6 (permalink)
Member # 1478
I say 44044s SOA.
Extinguish the light of rationalist authority and barbarous ignorance will be nowhere found.
Charly is offline   Reply With Quote Quick reply to this message
Old 08-04-2002, 11:53 AM   #7 (permalink)
Member # 5410
Send a message via AIM to Rob Kosinski
Do brand new stock waggies or find boneyard ones. I am using waggys from the boneyard up front and brand new ones from Jc whitney in the rear with a 1 inch body. The jeep is high, the 37s fit no problem and the 38.5 should also clear with ease. I think 4044s would give to much lift. I almost wanna go down in lift alittle since I can barely get in the thing and Im 6 foot. Just my opinion but get the extra wheel base if you can. Im rocking a smooth 100.25.........
Whaley Enterprises
84 CJ -4.0, 38.5,100 WB, 130 to 1
03 F-250-V10,6spd,4:30, Lariat.
Rob Kosinski is offline   Reply With Quote Quick reply to this message
Old 08-04-2002, 08:31 PM   #8 (permalink)
Member # 1792
He is SUA not SOA.He will not clear 37"ers SUA with these.I say 44044s SOA in front,F-150 rears SOA in rear.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 08-04-2002, 08:49 PM   #9 (permalink)
Member # 12878
35s are probably the biggest I can afford until I finish college.
Old 08-05-2002, 04:56 AM   #10 (permalink)
MKBruin's Avatar
Member # 6407
hell, if that's the case, jsut go JC whitney HD YJ packs on all 4 corners SOA.....you'll clear 35's with ease. (with a little trimming plus the body lift you are set to run 37's...)
run that, take the body lift off and sell it on JU to make up for your new drivelines. the HD springs and tj flares and you'll be set.
______________________________
"Did you think this forum served a legitimate socially redeeming function other than mental masturbation?" posted by Bobzooki
MKBruin is offline   Reply With Quote Quick reply to this message
