waggy mod 20 ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2002, 11:04 AM   #1 (permalink)
Member # 781
waggy mod 20 ?
Has any one used cj7 wide track warn full floater kit in a waggy mod 20? My cj7 20 housing is bent and has been twisted. I would like to use the thicker tubes, and install my detroit and the rest of the parts I all ready have.Any input Thanks. And yes I should have built a 6o from the begining.
84cj7,soa,4to1,T-18,456's, locked f/r, full floater, 35in.SSR
fixingjeep is offline   Reply With Quote
Old 08-12-2002, 11:14 AM   #2 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
99% sure the warn full floater kit will NOT work. The housings are different between teh waggie and the CJ. Thats why I'm dealing with making my own version of a bolt on floater kit. (getting close, just getting bid prices for some machine work.)
Travis Waldher is online now   Reply With Quote
Old 08-12-2002, 06:43 PM   #3 (permalink)
Member # 2095
Are you talking about narrowing the Waggy housing to the CJ width? Obviosly, the shafts would be too short otherwise.
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
Old 08-12-2002, 08:07 PM   #4 (permalink)
Member # 781
Yes ,narrow the housing to cj7 width,weld on the ends that match the spindles,and use the rest of my parts.
Old 08-13-2002, 09:28 AM   #5 (permalink)
Member # 4878
I know you have a waggie housing there.. but DAMN! wouldn't it be easier to find a CJ housing?
Old 08-13-2002, 05:53 PM   #6 (permalink)
Member # 2095
Yes, but the Waggy tubes are stronger.
'02 Z71
Old 08-13-2002, 06:11 PM   #7 (permalink)
Grendel's Avatar
Member # 10448
Send a message via Yahoo to Grendel
If you can get the CJ ends welded straight onto the the waggy housing, I don't see a problem.
We did it a while back. Had a slight alignment problem with the spindle going on. The bearing "bucket" was off a wee bit. SInce you don't use that bearing in there anymore, it wasn't much of an issue. We shimmed the spindle on and it's been taking abuse for two years now.
Grendel is offline   Reply With Quote
