Frame build tube or square - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2009, 03:58 PM   #1 (permalink)
Member # 70202
I now frame builiding has been covered alot but what are the votes for tube or just square. If I go with tube I was thinking about 1.5" 1/8 thick and have two rails with short notch pieces in between; and of course if go with square thinking about 2x4 3/16 or 1/4.
jesuscowboy is offline   Reply With Quote
Old 01-05-2009, 04:20 PM   #2 (permalink)
Haggar's Avatar
Member # 11570
Perhaps you ought to state what this is for, what type of suspension, how much stock equipment, etc, you are trying to mount to this frame.
Swamp Stompers 4x4 Club
Haggar is offline   Reply With Quote
Old 01-05-2009, 04:25 PM   #3 (permalink)
zachv's Avatar
Member # 8108
I say use 2x5" 3/8" wall. That will be light.
AtoZ Fabrication, Inc.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
We also offer the best service and prices available on:
Advance Adapters
Clayton Offroad Suspension
Raceline beadlocks wheels
Amsteel Winchline and accessories
ORI struts and Radflo shocks
Read my story about Todd at F&S Racing in the Bad Sellers forum
zachv is offline   Reply With Quote
Old 01-05-2009, 05:45 PM   #4 (permalink)
Grauss's Avatar
Member # 121348
Just don't do what DECO did...
But seriously, depending on what you want to do with it makes a big difference. If you want to do a buggy you could do all tube, or you could do a square subframe with tube. If your just rebuilding a jeep frame, I'd say 2x4 or 2.5x4 and do 3/16th wall, 1/4 wall is just overkill in my opinion unless you plan on dropping it off a very tall cliff...
87 YJ sittin on locked tons and 40 iroks
06 TJ rubi
Grauss is offline   Reply With Quote
Old 01-05-2009, 07:43 PM   #5 (permalink)
Member # 107843
Send a message via MSN to Bump&Grind
ah booty fab how I missed thee. Tubing is easier to work with, mitre cuts and such but tubing looks so much cleaner.
Bump&Grind is offline   Reply With Quote
Old 01-06-2009, 01:27 PM   #6 (permalink)
charlieboyd65's Avatar
Member # 31211
At least Deco built his own junk (which doesn't seem to have fallen apart yet). Gauss, tell us all about your build on your YJ and Rubi...
Maybe you should lay off trashing others that actually build their own stuff, when you are merely enjoying the fruit of someone else's labor on your daddy's dime (ie. buy an already built rig, but don't fabricate shiat).
Nothing wrong with buying a built rig, but don't talk smack about someone else learning to fabricate and working on their own project, when you are too afraid to fire up the welder and grinder.
You were trashing him on his build thread, like a little punk and doing the same here. You have 0 room to talk. Put up or shut up!
Sure, Deco has some things to learn with fabricating (and grammar), but you also have a few things to learn about life.
79 CJ-5, D44/9", 4 link F&R, 37's...and such.
Disclaimer: My useless ramblings should in no way be taken as fact, and I will not be held liable for any carnage inflicted because of said ramblings.
charlieboyd65 is offline   Reply With Quote
Old 01-06-2009, 01:33 PM   #7 (permalink)
Member # 105299
Send a message via MSN to big giant head
We all have to start somewhere, you just don't roll out of bed and start fabricating sick tube buggies, I say build it safe, and limit it to what your funds, skills and life can allow.
Edit: I guess I should post this in the other thread, but I have seen this jeep work and it does just fine for what it is built for. It is 100% DECO's and his old man doesn't drive it but, he gets enjoyment out of seeing his son drive and for some people that's more fulfilling than anything....
Owning a handgun doesn't make you armed any more than owning a guitar makes you a musician.
big giant head is offline   Reply With Quote
Old 01-06-2009, 02:26 PM   #8 (permalink)
Member # 119189
I would use a combination of round and square, it gives you the best of both worlds!
astjp2 is offline   Reply With Quote
Old 01-07-2009, 04:15 PM   #9 (permalink)
Member # 72053
Tube is tube whether its round square or rectangle. My advice based on the wording of your question is to hire an experienced chassis fabricator and forget about wasting any steel and electricity.
56Maynard is offline   Reply With Quote
Old 01-08-2009, 09:25 PM   #10 (permalink)
BnTMike's Avatar
Member # 197
I have built 3 now and all this way... stacked, strapped and plated... 3/16 2*4 and there is a 4degree kick to to match a cj-7 frame via pie slice and fold then weld and plate. the 4 degree kicks are in the sub frame only the front and rear rails are straight box tube
mike
LADD Racing #82 NCRR and 2014 KOH-EMC
Mike Ladd and co dawg Perry Hemre
Club Jackass Wheelers
TTC 1999
BnTMike is offline   Reply With Quote
