Member # 9363
gas tank safety
i have noticed how a lot of people move their gas tanks half in and half out of the bed of the jeep. but instead of cutting a huge hole in the floor i just put the whole tank back there. i am in the process of building a box around it right now, but this weekend i was with a few other guys and they said it was unsafe and that i should have a fuel cell. i just want to know what the difference is between a fuel cell and a gas tank, and how i could make this safe, if it is not. and yes i searched, but i didnt find anything about safety.
Member # 12393
I want to know too. I was planning on building a stainless steel flat tank for the bed with a sump for the fuel pump. I want to c move the rear axle back. If I vent the tank, put baffles in it and pressure test it, what's wrong with it. It can't be worse that the fuel cells without a steel or aluminum box, can it?
79 CJ-5 a bunch of stuff but no chrome, no Bestop, no Genuine Steel and no Steel Horse. 383 LT-4. D60, D44, D300 4:1, SM420, SOA, 4-link w/double shackles, etc. 88 YJ, 350TPI, 700R4, D300 4:1, rear SOA D44 w/Warn floating axles, coil front D44 w/Warn Axles |
Member # 987
There are different types of "fuel cells." Some are no different than a stock tank ... just blow molded poly tanks. IMO, there is no safety difference between those and a stock tank. And those blow molded poly tanks are what 75% of the dudes out there use.
The other 25% of the dudes are running some sort of bubba' fabbed metal tank (steel, stainless, aluminum). This is probably safer than a poly tank BUT only if an extremely competent welder does the work. I shouldn't have to explain why you don't want some novice welder messing around with a gas tank. If you really want safety, then you're talking "safety fuel cells." This is the kind of stuff that racecars use ... steel outer shells with a puncture resistant bladder inside. These are the ultimate in safety, but they are also the ultimate in price. That's why most guys don't bother. Run the stock tank in the bed, just make sure that it's secure and that nothing can puncture it. cmk |
Member # 3916
wouldn't you have a better chance of puncturing the tank under your Jeep rather than in it? knives from the camping gear maybe?
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB... The Build |
#6 (permalink) | |
Member # 987
It took 17 stitches to close him up and a size 11 boot to the head to kick it off the axe. cmk |
#9 (permalink) | |
Re: gas tank safety
Bud
http://www.dehesa4x4.com/pokey/ |
