torque converter bolts don't line up with flywheel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-04-2009, 02:53 PM   #1 (permalink)
Member # 125253
Has anyone had this problem? WTF? The motor is a 2006 6.0 from a GMC. The trans is a 2000 from an excalade. Both are LS motors. The escalade a 5.7 I believe to be LS1.
What now? new torque converter or flywheel?
chadroc is offline   Reply With Quote
Old 04-04-2009, 03:15 PM   #2 (permalink)
Member # 49116
What did the 6.0 have for a trans? And dont forget to try every spot. It will only bolt up one way. The Excalade I think would of had a 4l60E. You dont list what the 6.0 came from but i bet it had a 4l80E bolted to it. And there not the same flywheel. For one the 60e is 3 bolts and the 80e is 4 or 5.
Mach2_nh is offline   Reply With Quote
Old 04-04-2009, 04:07 PM   #3 (permalink)
Member # 25377
This.
Billy
Follow my build-up at [URL="http://www.bsfabrication.net"]BSFabrication.net[/URL]
JeepFreak21 is offline   Reply With Quote
Old 04-04-2009, 04:35 PM   #4 (permalink)
Member # 125253
It was a GMC Denali pickup. It may have had a 4L80E in it. I did try every rotating the converter 3 times. still it didn't line up.
Old 04-06-2009, 08:15 PM   #5 (permalink)
Member # 45700
Do some searching, this is a common issue. The LSX line has used a number of different flywheels. The bolt holes themselves could be the wrong diameter or orientation, or the dish/offset of the flywheel could be different too. Any LSX flywheel will bolt up to any other LSX. I'd say you probably have a flywheel for a 4L80 so it's different. Try and find one from a 5.3 or a 5.7 and you should be golden.
bbaXJ is offline   Reply With Quote
Old 04-07-2009, 05:05 PM   #6 (permalink)
mikef's Avatar
Member # 8948
That truck has a 4L65E a heavier duty version of the 4L60E.
89YJ EFI AMC 360, T18, D20, D44, 14 bolt, 38" Creepy Crawlers
mikef is offline   Reply With Quote
Old 04-07-2009, 05:08 PM   #7 (permalink)
bluecrawler's Avatar
Member # 88448
The 4l80e is the same bolt patern as the turbo 400 it will not line up with the 4l60e You will have to get the fly wheel for the transmission you are runing.
bluecrawler is offline   Reply With Quote
