Strange Problem With Jeep - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-02-2002, 11:56 AM   #1 (permalink)
Member # 11308
I have unusual problem with my Jeep and has gone on for some time and basically driving me crazy trying to figure it out. It runs sweet on the highway but as soon as I take it off road it starts to run very rough. Stalling out, backfiring etc. I'm not sure if it is from something getting wet or not. I'm assuming it is and looking for help/suggestions what to start looking for or at. It's been doing this for a while now and I've replaced rotor, cap wires plugs and ignition module. Any help appreciated before I lose my mind...It's a 78 CJ5 with 360 V8, T150
'78 CJ-5, 360 V8, T-150, Lockrights, 4" Suspension Lift, 3" Body Lift, 33" Super Swampers, One Piece Axles, Warn 8000
'96 ZJ, 318 V8, Up Country Package, Trac Loc, 30" BFG/AT...Yes it goes off road!!
[URL=http://mywebpages.comcast.net/mchumley3/pinebarrenadv.htm]Pine Barren Adventures[/URL]
[URL=http://mywebpages.comcast.net/mchumley3/jerseyjeeper.htm]Jersey Jeepers[/URL]
JeepManInNJ is offline   Reply With Quote
Old 09-02-2002, 01:53 PM   #2 (permalink)
Member # 5060
What carb you running?
Sounds like an advance, or carb issue to me. But what do I know.
OFFROAD= dirt roads? bumpy dirt roads? offcamber? up hill? down hill? Or just as soon as it leaves pavement?
MJ
Maine Jeepah is offline   Reply With Quote
Old 09-02-2002, 02:14 PM   #3 (permalink)
Member # 343
Tricky one...sounds like terrafirmaphobia to me!
cj8scrambld is offline   Reply With Quote
Old 09-02-2002, 02:41 PM   #4 (permalink)
Member # 11308
It's the Motorcraft 2100 2 barrel I think. Why would it only act up off road?
Old 09-02-2002, 02:50 PM   #5 (permalink)
"D"
Member # 4835
weak float springs maybe?
"D" is offline   Reply With Quote
Old 09-02-2002, 02:50 PM   #6 (permalink)
Member # 9328
Float level too high.
"Somewhere. Out there. Is a big ass forest of weed"--Thomas Edison (from Rolling Kansas)
landusepbb is online now   Reply With Quote
Old 09-02-2002, 06:48 PM   #7 (permalink)
Member # 11308
If the float level is too high, is the bouncing around off road causing it to have these problems? I can lower the float level and see what happens, but don't understand why this would make a difference?
I'm not sure I understand why it has no problems on the street but does on the dirt?? It runs great till I go off road. I know it sounds nuts but this is what is going on...grimlins???
Old 09-02-2002, 06:50 PM   #8 (permalink)
ItsaCJ6's Avatar
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
could be loose wiring ............
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Super conversion calculator website
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote
Old 09-02-2002, 07:09 PM   #9 (permalink)
Member # 11308
I've checked wiring to the coil and it is ok. What other wiring should I look at?
Old 09-02-2002, 07:41 PM   #10 (permalink)
Member # 13003
what exactly are you doing when it gets stupid?
are you just bouncing, or did you just go through a big puddle or what?
-web
78 CJ-5, undergoing frame off resto/mod, 360 w/custom mounts, t-150, 20, stock running gear
webjeep is offline   Reply With Quote
Old 09-02-2002, 08:13 PM   #11 (permalink)
Member # 12747
check vacuum before you spend any cash. I know you said it only acts up off road but think about it, you are going way slower off road and with less rpm then you ever do on highway
With friends like you guys, who needs enemas.
Lil'BlackCJ is offline   Reply With Quote
Old 09-02-2002, 08:15 PM   #12 (permalink)
Member # 11308
It seems to happen more often after going through water. It has happened just driving down flat trail wit hsome whoops. It's got me totally at a loss to figure out. Thought someone on here may have had a similar problem. If it does it more after going through water, what should I be checking? How can I rule out Carb short of changing it? I would think that a card problem would happen all the time?
Old 09-03-2002, 07:29 AM   #13 (permalink)
Member # 13408
I have been through a lot of the same troubles with mine...First thing I'd check, is the carb. Pull it off the intake take it apart and clean the mess out of it. More than likely there is a ton of crap in it. Buy a new fuel filter as well. Chances are when you are bouncing around you are moving the dirt around in the carb. Even if you have never done anything like taking a carb apart, they are relatively easy so don't shy away...Good Luck. (You might also feel as though you have gained about 20 hp too.
'78 Jeep CJ-7 Golden Eagle
360ci, NV4500, Dana 300 twin stick,
Dana 30 Fr. ARB, AMC 20 one pieces and detroit in Rear both with 4.10 gears
jeepgoldeneagle is offline   Reply With Quote
Old 09-03-2002, 10:24 AM   #14 (permalink)
Member # 5577
Runs bad after being in the water = Probably a wet distributor/wires/ignition module. Dry it out and seal off the problem area (dielectric grease on both ends of the plug wires helps, so does spraying them with a little WaterDisplacement 40.) If it's the ignition module, get a new one.
Runs bad after bumps = floats too high or possibly one is stuck. Adjust/rebuild the carb as necessary. A little foam in the bowls (below the floats) helps to prevent splashing.
HTH,
Jake
It's all here before your eyes / Safety is a big disguise / That hides among the other lies
Jakesteramalamajama is offline   Reply With Quote
Old 09-03-2002, 11:25 AM   #15 (permalink)
Member # 11308
I've replaced the ignition module already and same problem exists. Going to take carb off tonight and clean out real good and check floats. If that doesn't solve problem I'm looking to replace carb and go from there. I'll try the water proofing advise too. Short of these I don't know what else to do or try...
Old 09-03-2002, 11:32 AM   #16 (permalink)
Member # 5577
I'd dry out/seal up the distributor first. 9 times outta 10 that's the culprit in a runs-shitty-after-getting-wet type of situation.
If you have a vacuum advance arm that you need to seal around, a dollop of dielectric grease can help there too. It seals out the water, but still allows the arm to move in and out of the distributor. I had this problem on my old 258 until I sealed it up.
HTH,
Jake
