Ive sprung over my 84 cj7 with wrangler springs-factory, 44 front/60 rear, and have a set of f-250 shock towers for the front. looking for suggestions on shock lenth, and mounting positions . Also suggestions on shock brands that seem to be living on the trail. This jeep will be doing almost no street driving at all..Just don't want to have to invest a lot of money on the trial and error route if I can help it..Don't want to limmit travel, or pick the wrong spot and have to re-do a set of mounts..
i am pretty sure that the Rancho 9012 (5012 if you want non-adjustable) is the longest shock on the market, besides external reservoir shocks, i run RS9000's and plenty of my buddies run them and so far none of the shocks have given major troubles and have lasted for quite a while, the 9012(or 5012) has an eye on either end so your F-250 towers should work, you pay for quality so the RS9000's run a little under $300 for all four unless someone else on the board can get them cheeper
Rancho now makes a shock longer than the 5012/9012. It has around 15" of travel...unless your fullwidth, you will probably never use that much though. 9012's work great for the front...put what ever will fit in the rear and you can angle them to get more travel out of them. In the pirate bible, there is a shock length chart that you can download.
I am SOA with 2 1/2" Superlift springs om my CJ-5. I run 5012's with the Ford Towers up front. The bottom of the tower is about even with the bottom of the frame rail and the top of the tower is angled back slightly. It works great for me. Later, Casey
I have a set of 9012's front and rear on my full width YJ. I bottom out the front ones only when in extreme droop and the rears NEVER come close to bottoming, or topping. They're angled in at about 40 deg. The only thing I'd change is I would have bought the 5012's because they're cheaper. I honestly never mess around with those adjustable knobs. I set them and left them alone, plus alot of people end up breaking off those dinky plastic knobs anyways.
The Bilstien 5100 series comes in a version that is about 1" longer than the 5012/9012.
I ran R9012's for more than 5 years, and I liked them a lot except for on steep climbs when a little quicker dampening was needed to help keep the shocks from packing up,...then I ran the Bilsteins at the recomendation of Bob Roggy, and I have never looked back.
U get it (Kevin, from the Pirates) just did a write up on his Bilsteins.
The 5100's cost about the same as the R9000's and come nickle plated.
I run the 5100's in the front and remote resrvoir 7100's in the rear (custom valved to be used on a 45 deg angle, and set up for very quick rebound). Custom Valving and dampening is an option with the 7100's along with remote reservoirs, (cost: about $170 each, with reservoirs).
Ranchos, are a good shock, but Bilsteins out perform them hands down, in my opinion.
Speaking of the Ford Shock Towers, what's the difference in height of those F250 towers compared to the 82+ Jeep towers? My 79 had the shock towers on it till this weekend. I found an 84 CJ in the junk yard, and unbolted those to install on my 79 (which is also SOA w/ YJ packs), but was told I should use the Ford towers instead. How much longer are the ford towers over the 82+ CJ towers?
Thanks,
Chris
