question for you. a jeep chick friend of mine cracked her belhousing on her TJ the other day. she has a 2000. my question is will a 93 and up yj 4.0 to ax15 bellhousing work?. I know YJ and tjs had different pilot bearings but as far as I know that is the only difference. I found this out b/c I have a 98 4.0 in my 94 yj with a 90 ax15.
so will a 93+ ax15 Bell housing work on her TJ. these would make a junk yard search much easier.
also if she has a nv3550 will the same bellhousing work? it was 2000 that the nv3550 was introduced right?
PS in case you haven't figured out I am not a tj person.
