da new tj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2009, 01:20 PM   #1 (permalink)
Member # 108318
da new tj
Well figuired id start a build thread of my new tj so i have some sort of catalog of events and to ask for help as it progresses. It starts out as a 06 tj (ive made 2 payments and thats about a record for me to leave something alone) Got a 14 bolt for the rear and am still scouring for a front 60. Had a rubicon express long arm on it for awhile and am going to base the new susp from that. Got my new tires on fri. The new goodyear mtr's, daum 40's look kewl
I got so mutch travel i need a good sam sticker
gg's cj5 is offline   Reply With Quote
Old 06-21-2009, 01:40 PM   #2 (permalink)
Member # 108318
Some of the 14 bolt...or should i say 13 bolt? Shaved an inch off, welded the tubes and plated the bottom to make it a lil smoother. nothing too special.
Old 06-21-2009, 01:55 PM   #3 (permalink)
Member # 108318
It was pretty flexy with the rubi kit but i dont have to tell any one here about the shortcomings of the dana 35, even with alloys. Thats me fixing a axle on jack north.
Old 06-21-2009, 02:03 PM   #4 (permalink)
Member # 108318
had some driveline vibration when i first installed the rubi kit so i dropped the t case a lil and it worked sweet.
Old 06-28-2009, 05:56 PM   #5 (permalink)
Member # 108318
made some sliders and waterjet out my company name.
Old 06-28-2009, 06:05 PM   #6 (permalink)
Member # 108318
poly performance truss
Old 06-29-2009, 03:04 PM   #7 (permalink)
timritchieblue's Avatar
Member # 120912
just checkin in
2000 tj with some stuff
2001 C5 COUPE
timritchieblue is offline   Reply With Quote
Old 06-29-2009, 07:35 PM   #8 (permalink)
Member # 124842
Poor sami jeep is bitching though
derteracing is offline   Reply With Quote
Old 06-30-2009, 12:12 PM   #9 (permalink)
Member # 108318
some of the front 44. I couldent find a 60 fast enough so i am going to use this for awhile than i will sell it.
Old 06-30-2009, 12:18 PM   #10 (permalink)
Member # 108318
some of the 14 bolt
Old 06-30-2009, 02:14 PM   #11 (permalink)
Member # 120523
damn lookin good! and way to not waste and time with leaving it stock haha
mjw4669 is offline   Reply With Quote
Old 07-03-2009, 09:39 PM   #12 (permalink)
Member # 108318
So.. one of the reasons i chose a 14 bolt was the supposed incredible amount of aftermarket support, i mean the thought of not being able to get gears never even entered my mind. Come to find out none of the 5 major players in the gear industry i called could help me out cuz 5:38's are backordered out the yazoo. needless to say i was pretty bummed. I found out about east coast gear supply and man they hooked it up. Thanx alot guys. Gears should be here by mid next week and that is all im waiting for to put the axles in. sooo close......
Old 07-03-2009, 09:57 PM   #13 (permalink)
Member # 120238
jeeps looking sick dude. What do you think your shootin for with the wheelbase?
nahmus:no that little nugget of wisdom came right from the retarded circus of my mind.
mountain_yj is offline   Reply With Quote
Old 07-04-2009, 11:22 AM   #14 (permalink)
Member # 108318
Well the plan was to put tire infront and behind it but due to lack of time im just gonna put it back together without stretching it just yet. the wb will be around 94-95" for now but trust me it wont be that way for long. My plan is to do the rear first one week than the front another week. In the end i want to be around 105" or more. I am still trying to figure out how i want to do the rear. I am going to use this as a dd and want it to be as ergonomic as possible. I want to be able to fuel it up from the outside and dont want to hear fuel pumps and fuel sloshing around, nor do i want to smell gas. I am going to build my own cell but halfway french it in the floor than sheetmetal over it. Ive seen some ideas simalar to what i want to do and it looks pretty clean with all the extra effort. That way i can still have my cell relativley under the jeep and put my ice chest behind the rear seat still. The front is still up in the air with what i want to do for the steering, i dont want full hydro but i want an extreme stretch. I will most likley have my friend that owns a steering remanufacturing company build or find me a box with the pitman output farther to the front. Ive heard the trick is an astrovan box but i havent researched it that far yet. Eventually i plan to highline the front fenders about 3" than minitub the rear so i can raise them up as well. I want the center of gravity to be as low as possible. I was kinda bummed how low the rubicon express skidplate sits (like 3 inches below the frame) but oh well.
Old 07-04-2009, 03:43 PM   #15 (permalink)
Member # 117513
Send a message via AIM to Schvin
Your welds look great, I think anyway. What kind of welder are you using? Thanks.
Schvin is offline   Reply With Quote
Old 07-05-2009, 07:31 PM   #16 (permalink)
Member # 108318
Thank you. i have a few different welders for different jobs. I use a lincoln powermig 255 for steel, and i use my miller syncrowave 200 for stainless, chromo and aluminum. I also have a miller 140 for small jobs and a bobcat with a suitcase welder for the really big stuff. I actually used 3 different welders on my axles. I used the powermig 255 for all of the brackets that are on the tubes than the syncrowave with nirod for the cast sections. on the front axle i used the syncrowave again and tigged on the big spiderweb gusset. and on the tubes to the center sections i used my 140 with innershield. (if you get the cast hot enough with a torch first the innershield bites really well)
Old 07-05-2009, 07:41 PM   #17 (permalink)
Member # 117513
Well I think they look great. Which one did you use to weld the truss/CA brackets together?
Old 07-06-2009, 05:17 PM   #18 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
all of em.....
DJ404564X4 is offline   Reply With Quote
Old 07-08-2009, 12:05 PM   #19 (permalink)
Member # 108318
Originally Posted by DJ404564X4 View Post
all of em.....
Yeah, what he said. I used everything in my arsenal
Old 07-14-2009, 04:19 PM   #20 (permalink)
Member # 108318
Well i have been a buisy man this weekend, finally had time to work on my stuff. heres the brakes. i used 82 1/2 ton 2wd chevy front rotors and 02 f350 calipers. cut some 1/2" for the caliper mounts.
Old 07-14-2009, 04:26 PM   #21 (permalink)
Member # 108318
Axles are in and it runs. I have less driveline vibration than before and the tires are super quiet. No matter how you try to overcome tire size with gearing you still feal a little power loss though. Now im acumulating parts for stage 2, the stretch. Im gonna do the front first than the rear another weekend. Not bad for getting the axles done in less than a month. it would have been less if i had the axles when i started but i started dismanteling before i even had sorced out the axles, than i had to deal with gearing avalibility drama.
Old 07-19-2009, 08:48 PM   #22 (permalink)
Member # 108318
Tryed it out today. it works pretty well, im gonna have to get used to the height its alot taller than it used to be. Rubing was expected ill just deal with it till i get my armor.
Old 07-19-2009, 10:04 PM   #23 (permalink)
Member # 77789
nice bro, what size coils are in there.
xxxjeep jake is offline   Reply With Quote
Old 07-20-2009, 12:15 AM   #24 (permalink)
miguelitojeep's Avatar
Member # 73093
you know your tires are on backwards right, or just the passenger side? they are directional tires....
KOH 2013 Bom-Tec Racing #4476
miguelitojeep is offline   Reply With Quote
Old 07-20-2009, 10:23 AM   #25 (permalink)
Member # 108318
The coils are 4" lift, i made a 3" spacer for thr front but the coils will be replaced by air shocks or coilovers soon. Actually the tires arent directional i dont know why they arent. If you want the all terrain tread in the middle than one side of the tread will be facing the other direction but because all are the same if you want the tread to be facing the same than the all terrain tread would be offset to one side. im not sure why they did it like that. either way you mount them they look odd, i rather have the all terrain part twards the inside than have it off center not like it really matters anyway they are so freaking huge.
