Project: "Stretch it" - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-12-2010, 12:17 PM   #126 (permalink)
Swamp Crawler
Blase's Avatar
Member # 63692
Originally Posted by texasag02 View Post
Need some opinions......
- Option 1: Spool front and rear. Spool front and rear equals unmatched reliability. Spool in the front can bring the suck with steering, but I will have full hydro and the ability to disengage the front with the Atlas if necessary. On the road I can unlock the front hubs or remove the drive slugs (depending on what I run). Extended wheel base and spool can bring the suck. On road driving will be predictable but cause faster tire wear.
- Option 2: ARB front, Spool rear. Predictable on road with the ability to turn off front locker to turn better/sharper offroad. ARB, not as reliable.
- Option 3: Spool front, ARB rear. Best on road driving with the least amount of tire wear. Can unlock rear and use front to pull me through the turn but can cause the front to walk out of the turn.
First off I run ARB's in HP 60's front and rear.
So with that said I would run with option number three as an alternative to running ARB's F&R.
When wheeling WITH FULL HYRDO I rarely unlock my front end. I find (guess found is more appropriate since my rig has been apart for over a year)my rear end only gets locked when I need it. So most of the time I’m running a Spool or locked in the front and open in the rear.
On the flip side I used to run with the front unlocked and rear end locked all the time and my steering brought the suck!! The rear end would just make the front end push even though the front wheels turned full lock. It didn't even matter if I disengaged the T-case it would still push.
As Far as the street goes As long as the t-case is not trying to turn the front axle it will drive OK. If you pull the slugs it will be just like driving a jeep with NO lockers.
Option number three for me.
With cutting brakes and a selectable locker(ARB) you can get through 95% of trails with the front end locked.
P.S. Dave is a big help on a project like this!!!
It's........It's.......SOLD
/forum/general-4x4-discussion/781848-blases-k-o-r-e-chassis-build-up.html
http://www.jak4x4.com
Originally Posted by JR View Post
You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.
Blase is offline   Reply With Quote
Old 01-12-2010, 06:04 PM   #127 (permalink)
rkik's Avatar
Member # 34591
I'm leaning toward a spool in front and an ARB in the rear with a cutting brake for the rear wheels only.
That sounds like a good plan. FWIW I run a spool in the front and welded rear and do the occasional drive around town in nice weather and have no ill effects besides some extra tire wear on the rear.
rkik is offline   Reply With Quote
Old 01-12-2010, 06:12 PM   #128 (permalink)
Member # 68602
Thanks for the info! Dave is trying to get me to run spools front and rear
When we get our rigs together we will have to go test them out
texasag02 is offline   Reply With Quote
Old 01-12-2010, 06:13 PM   #129 (permalink)
Member # 68602
Thanks man! I go to your build many times to get ideas and refrence
Old 01-24-2010, 07:43 PM   #130 (permalink)
Member # 68602
Made a lot of progress over the weekend! Got everything situated under the Jeep and got the tires on. I also got the hi-line fenders on and installed the hydroboost on the firewall.
As you can see it is missing the hybrid coilover. The axles are actually welded to the frame. I am headed up to my buddies fab shop (ATX Customs) in Amarillo on February 9th for 4 or 5 days to complete the major parts of the build. We will be building the rear frame section, front frame section, roll cage and front hoops!!! It is going to be some long days
I will get some better pics, but this is a hydroboost and MC from a 2004 Dodge 3/4-1 truck. The guy I bought it from made me a custom bracket and modified the arm that hooks to the pedal. He did great work. If you are interested in something similar send me a PM and I will get you his info.
Old 01-24-2010, 07:48 PM   #131 (permalink)
Member # 68602
FYI it is sitting pretty close to ride height.
Some dimensions:
  • Overall height - 77"
  • Bottom of Frame - 23"
  • Clearance above rear tire to tub - 6.5"
  • Clearance above front tire to fender - 7.5"
  • Wheelbase - 111"
Old 01-28-2010, 01:14 PM   #132 (permalink)
Member # 115225
when are you going to do some garage surgery to get that thing out of there?
senterd is offline   Reply With Quote
Old 01-28-2010, 03:34 PM   #133 (permalink)
Member # 141733
Great looking rig man.
Question for ya, why is your spindle mounted outside the caliper bracket? I don't guess it would hurt anything and actually gain you say and extra 1/4" WMS each side. I know my chevy 60 has the spindle mounted behind the caliper bracket.
Krawlher is offline   Reply With Quote
Old 01-28-2010, 04:15 PM   #134 (permalink)
OkLaHoMaYJ's Avatar
Member # 17969
Send a message via AIM to OkLaHoMaYJ
My 78 HP60 was the same way. Brake shield, caliper bracket, spindle.
2012 F150 FX4 EcoBoost - Wanting a built LJ/JKUR
OkLaHoMaYJ is offline   Reply With Quote
Old 01-28-2010, 04:16 PM   #135 (permalink)
Member # 68602
Yep that is the way it came off
The Chevy 60 is opposite as you indicated.
Old 01-30-2010, 06:56 PM   #136 (permalink)
Member # 68602
Got it out of the garage today
Also got the old cage out to make room for a new one
Old 01-30-2010, 07:41 PM   #137 (permalink)
sureshot40sw's Avatar
Member # 18435
Send a message via Yahoo to sureshot40sw
very nice... mine will be similar in stature..
My grandma says..." if she'll put a cig in her mouth,she'll take a dick in the ass" --- EricT
sureshot40sw is offline   Reply With Quote
Old 01-31-2010, 01:49 AM   #138 (permalink)
CAPTIN INFERNO's Avatar
Member # 118706
Wink
It looks SICK, love the stance!!
CAPTIN INFERNO is offline   Reply With Quote
Old 02-04-2010, 10:26 AM   #139 (permalink)
JORDANJ's Avatar
Member # 147452
LOOKING GOOD. WHERE ARE YOU GETTING YOUR CAGE? I JUST ORDERED MINE FROM ESSENTIALLY OFFROAD. IF YOUR OLD CAGE WOULD FIT A YJ I CAN GET IT SOLD FOR YOU.
JORDANJ is offline   Reply With Quote
Old 02-05-2010, 09:34 AM   #140 (permalink)
Member # 68602
New cage is a custom cage that will be built by ATX Customs. Old cage is sold, but thanks for the offer
Old 02-10-2010, 10:45 AM   #141 (permalink)
Member # 68602
Headed up to Amarillo yesterday (Tuesday) to spend the next five days at ATx Motorsports with my buddy Derek and his crew knocking out the rest of the work on the Jeep!
Getting the Jeep on the trailer was fun with no drivetrain or brakes
First we got the Jeep up on the frame table and got the rear frame cut off.
Derek and Ryan from ATx posing with the rear frame.
Old 02-10-2010, 10:47 AM   #142 (permalink)
Member # 68602
While we were waiting for the rear transition pieces to be cut I removed the front hoop and stinger.
Today we are tackling the rear frame and we will start on the cage!
Old 02-10-2010, 11:25 AM   #143 (permalink)
tjjared413's Avatar
Member # 46942
nice man!!!!
04tj with round tires
04 d-max tow rig
tjjared413 is offline   Reply With Quote
Old 02-11-2010, 06:49 AM   #144 (permalink)
Member # 68602
Progress yesterday on the rear frame:
Old 02-11-2010, 06:54 AM   #145 (permalink)
Member # 68602
Old 02-11-2010, 08:40 AM   #146 (permalink)
myke52081's Avatar
Member # 79098
That rear frame section is sick
1993 Wrangler
2006 Dodge Cummins
myke52081 is offline   Reply With Quote
Old 02-11-2010, 08:57 AM   #147 (permalink)
JORDANJ's Avatar
Member # 147452
Why did you take off the hoop and stinger?
Old 02-11-2010, 12:11 PM   #148 (permalink)
Member # 41947
Looks good!! We need to go wheel we are both done!
[SIZE="6"]CALL OR EMAIL ME FOR FASTER RESPONSE[/SIZE]
Chip MacLaughlin
Pringle Fab
832-813-9055
[email]chip@pringlefab.com[/email]
Pringle Fab - Your South Texas Off Road Speed Shop!!
We are authorized dealers in ORI Struts, PSC Steering Components, Raceline/Allied Wheels, PRP Seats, Ruffstuff Specialities, Nitro Gears, Novak Conversions, Stage 8 Off Road fastners, and much more!
For every $500 spent with Pringle Fab, you will get a chance to win a 20 qt Yeti! Only 40 chances will be given. Get your chance now!
Also find us on facebook - [email]pringlefab@gmail.com[/email]
iispms is offline   Reply With Quote
Old 02-11-2010, 12:13 PM   #149 (permalink)
Member # 123044
If your not gonna reuse the front bumper and hoop I would be interested in buyin it from you. That is if your not using it.
[URL="http://rme4x4.com/showthread.php?t=81175"]1997 TJ, 5.2L V8 Swap[/URL]
Slangy is offline   Reply With Quote
Old 02-11-2010, 12:55 PM   #150 (permalink)
513
Member # 121037
That's a great idea for reworking the rear frame, nice and simple. Jeep is looking awesome
Matt - Dreaming of AZ wheeling.
513 is offline   Reply With Quote
