Think I could get by with a heavy duty air powered cutting wheel?? I really cannot justify the cost for buying a cutting torch?? However I could rent one for 28 dollars with 3 hrs of use.
A sawzall with a 14tpi blade works just fine. Doesn't create all the dust and mess that a cutoff tool does either. The sawzall is my tool of choice for cutting anything up to about 3/16".
Gas axe, cut-off wheel, sawzall, angle grinder, plazma cutter, hack saw, butter knife, any will work, just don't cut into the frame, if you're unsure, you can always cut more, it's hard to cut less after.
When I stripped down my YJ chassis I found it easier to grind the welds with a angle grinder then get them stared with a cold chisel and a BFH. Once you get the weld seperated from teh chassis and the mount the hammer and chisel do a nice clean job of removing the old brackets along with the welds.
I also used a torch to remove some brackets but was left with hours of grinding to clean up where the mounts had been cut off.
get some cut-off wheels for your grinder. i think ACE hardware has them, and Home Depot has them.
typically, they are 4.5"-6" diameter, have a 7/8" arbor, and are 0.045" thick. usually they cost $2-3 each. i usually get 3 or 4 at a time.
matt
