Member # 9587
T-18a problem
When I put it in 4 it rattles. Not on the throttle but when I coast it. My mechanic put new bearing in it an it still does it. HELP
06 LJ Rubicon 79 CJ-7 with stuff |
Member # 126928
my t18 or dana 20 does it when im coasting or get the speed just right going down the road. like i said im not really sure weather its the transmission or transfer case but i just figured they were all like that.
#4 (permalink) | |
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
Which?
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. |
Member # 6340
Not mine...But fourth only gets used in Low range at high speed.
Member # 9587
It does it in 4th gear 4 wheel drive hi and 2 wheel drive. I don't know if it would do it in 4 low. If I throttle it, it would NOT rattle but when I coast it rattle big time.
Member # 17680
Make sure the nut holding the t-case input gear to you tranny's output shaft hasn't come loose, that can cause the sounds you are describing.
'50 m38, 60, 14bolt, 4.3, 420, dana 300, 35" krawlers on trailready's/ '80 Blazer 60,14 bolt, tpi 350, th400, 205, 35" swampers Link to my M38 build: [url]http://www.pirate4x4.com/forum/showthread.php?t=703554&highlight=willys+m38[/url] |
Member # 6340
This is possible.
