Long story short, we ordered the "navajo" brake booster system from off-again yesterday & had it overnighted (don't have time to explain why right now)
Anyway, we got it today, the system comprises of a dual diaprham booster, m/c, bracket & adjustable rod.
Rick took the m/c off & bench bled & we mounted the booster to the firewall & attached the rod. However, when the m/c is mounted to the booster, pressing in the pedal doesn't push any fluid. It appears that either a: the pin in the end of the booster is too small for the m/c or b: the m/c is too bid for the pin.
This is on an '85 CJ7.
Here is a picture of the "navajo" booster:
here is a picture of the stock CJ booster:
here is a picture of two m/c's the one on the left is a wagoneer m/c, the one on the right is the CJ m/c:
here are two pictures of the end of the "navajo" m/c
When the pin (or rod or whatever) presses into the "navajo" m/c it isn't pushing against the washer type thinggy.
(sorry for the vagueness)
any thoughts? Has anyone used this setup? Should I just go ahead & use the CJ m/c for now - I am supposed to leave for the badlands tommorrow at noon.... and YES, I tried to call off-again about 10 times.
-Mel
-Mel
