Can I see your Waggy 44 spring mounts? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2002, 08:40 PM   #1 (permalink)
PIA
PIA's Avatar
Member # 1739
Specifically front driver side SOA with all of the diff webbing mess. did search, couldnt find. thanks
If the path does not have any obstacles, it probably won’t lead you anywhere
PIA is offline   Reply With Quote
Old 09-23-2002, 12:03 AM   #2 (permalink)
Brad's Avatar
Member # 3239
Send a message via AIM to Brad Send a message via Yahoo to Brad
pass. side
dont know if this helps either
B-RAD Fabrication
TDO DYSFUNCTIONAL ROCKCRAWLERS
Brad is offline   Reply With Quote
Old 09-23-2002, 03:56 AM   #3 (permalink)
Member # 498
Send a message via ICQ to WheelingPiazza Send a message via AIM to WheelingPiazza
You mean something like this?
KI6PZZ, One of the wheelingpiazzas.
Dysfunctional Rockcrawlers (TDO)
WheelingPiazza is offline   Reply With Quote
Old 09-23-2002, 04:35 AM   #4 (permalink)
Member # 7163
If you wait til after next weekend, I'll get some. I just ground mine down yesterday.
Bryan
Oxjockey is offline   Reply With Quote
Old 09-23-2002, 11:06 AM   #5 (permalink)
Member # 10891
Don't have any pictures as of yet. But I measured the height of casting off the tube, and cut this amount off a new spring perch. The height of the casting is slightly greater towards the rear of the tube. Also had to grind down about 1/2 inch of webbing in order move the perch inbound on the raised casting 1/2 inch on my YJ.
chad
cisrael is offline   Reply With Quote
Old 09-23-2002, 05:49 PM   #6 (permalink)
PIA
PIA's Avatar
Member # 1739
thanks for the tips. i will have at it tonight. pics would still be nice though if you get a chance
Old 09-25-2002, 05:39 PM   #7 (permalink)
PIA
PIA's Avatar
Member # 1739
would like to see u bolt setup too. im thinking i may have to use a couple flat plates.
Old 09-26-2002, 02:53 AM   #8 (permalink)
Member # 7163
I thought about that, but the plate on the bottom may not fit with the chunk/cover being right there.
Bryan
Old 09-26-2002, 06:34 AM   #9 (permalink)
Member # 10891
for the Ubolt setup, I had some square bolts made up. Since the perch is moved in 1/2 inch, on my 94 YJ, it give just enough room to slide the outside bolt on the casting. With the grinder gut a small grove down the casting 1/4 in from the outside so that the bolt will sit in this grove and not slip off to the tube. Also on the spring plate, the width of one set of wholes is narrow than the other. Since both bolts would be now be over the casting I blew the holes a little wider so that they match up in width.
