Member # 129631
HyLine Hemi Build
It's time for another great build by T&T Customs! I'm calling this one our HyLine Hemi build. You thought Cody's 40's on 4" were nice how about 42" MT/R's on 4.5"? To make it all the more fun this Jeep has already gone through AEV and had a 5.7L Hemi dropped in it :drool:. Between the Hemi and the 5.13's in the ProRocks your face automatically goes
when you hit the gas! The Jeep currently sits on 37's and a RE longarm system. We are going to be upgrading the suspension with our Rock-Trek Long-arm Suspension, stretching the wheelbase front and rear, installing our HyLine Full Replacement Tube Fenders and HyLine Stretch Corner Armor along with our "Guardian" front bumper, rock sliders, tire carrier, replacement rear crossmember, etc..Here it is.. ![]() ![]() 37's rubbed on 5.5" ![]() 42's
T&T Customs, Inc. - "Go Equipped" We offer a 10% Discount for all active duty military personnel!! |
Member # 129631
![]() ![]() The transmission is big and is running a deep pan so we'll be fabbing a custom BP for it. ![]()
Member # 129631
Front stretch
On Cody's build we moved the the front axle forward to gain a couple more inches of wheelbase. We did this by rotating the steering box and moving the coil mounts on the axle along with some other modifications that I'll show later. His steering box was based off of a 4-bolt YJ box so all we had to do was notch the crossmember for clearance. This Jeep has the factory Mercedes style box which is considerably larger so just notching the crossmember was not going to be possible, it needed to be moved.
Before shot ![]() After, using a new crossmember tube. ![]() You can see how close the box is even to the new crossmember. We'll be making some plates to tie the new crossmember to the frame and to re-strengthen the frame rails and act as a steering box mount. I'm sure that you've noticed that the front tube is smaller than the factory one. We've been working with ORO on a custom mounting setup for their dual rate SwayLoc swaybar. Which we give a huge :thumbsup: to! We have been running the SwayLoc on a couple of our shop rigs and after running several other brands, it is by far our favorite setup, and is getting installed on the rest of our rigs.
Member # 69669
Why not cut out the tube off around the rail and leave the frame sleeved for extra strength, and cut a circle in the new spot and slide the tube in from the side instead of the front to keep your joints tight?
[URL=http://www.standardproduce.com/]Standard Produce Co.[/URL] Serving Central VA Since 1910 93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There :grinpimp: Last edited by cavaliers1323@aol.co; 10-16-2009 at 01:49 PM. |
Member # 129631
Finally got an update for you! :thumbsup:
Here you can see the new steering box/crossmember mounting plates. If you remember from earlier posts we are stretching the front without cutting and lengthening the frame. To achieve this we rotate the steering box which in turn moves the pitman arm forward. We then relocate the coil mounts on the axle tube. We are looking to gain right around 3" of wheelbase just from this. Once we complete the rear stretch the overall wheelbase should be 101". ![]() ![]() Here's a preview of the 42's with 3.5" of lift :drool:
Member # 69669
Was that origanally a three bolt box?
[URL=http://www.standardproduce.com/]Standard Produce Co.[/URL] Serving Central VA Since 1910 93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There :grinpimp: |
Member # 93306
just curious you did a very good job on the steering box move but why not just go with an astro van steering box and save yourself all the pain in the ass work and also figuring out the swaylock setup? seems like thats alot of work that a brand new $175 steering box could have fix right out of the hole and bolted right up and gave you up to 7" of front stretch?
[COLOR="Red"]BUY MY JEEP $7000 OBO:[/COLOR][url]http://www.pirate4x4.com/forum/showthread.php?t=754738&highlight=cheep+jeep[/url] Last edited by bardenk1; 10-23-2009 at 05:17 PM. |
#12 (permalink) | |
Member # 129631
This is the last rig we featured on here when we first came out with our HyLines and doing this front stretch. In this pic he's running a different swaybar setup but even then, between it and our suspension geometry his Jeep handled like a sports car. We recently upgraded it to the SwayLoc and now it's even more fun to drive on the street, yet it still retains it's offroad capability.
