Full Hydro Reservoir Mounting - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-29-2009, 02:52 PM   #1 (permalink)
Member # 116355
Where are you guys mounting your reservoirs for your full hrdro steering? Im having trouble getting the reservoir high enough to have the outlet above the pump. I have a yj with the 4.0L so the pump is on the top of the serpentine loop. I would have to drill a hole in my hood and stick it through there. please post pics of where your mounting them. Any ideas?
jasn123456 is offline   Reply With Quote
Old 10-29-2009, 02:55 PM   #2 (permalink)
KyleQ's Avatar
Member # 83837
Early bronco is probably just as bad... I used a -10an to -10an fitting to directly mount the reservoir on the pump and built a support bracket. It sticks out of the hood, but will never starve the pump. I tried mounting it lower to fit under the hood and it killed the pump.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
Old 11-05-2009, 06:10 PM   #3 (permalink)
Addicted
Autodocgi's Avatar
Member # 117078
I mounted mine on the radiator support, right where the factory one was at. It's a tight fit, but just clears the hood.
I made a bracket to hold the reservoir mount and adjusted it up as close as I could.
Trick I did for the suction line, was to use the factory suction hose(has a pre-formed 90* bend). After cutting it to the right length, it fit perfectly.
Couple of pics....
Edit: obviously the zip straps are temporary...
Autodocgi is offline   Reply With Quote
