convert to hydro clutch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-30-2002, 10:28 PM   #1 (permalink)
Member # 2521
Yes, I searched, and of 43 posts on this none were all that particular.
I gather you can use 81-84 4 banger hydro master, slave, and line to convert a 77 CJ-5 with 401, stock T-150 bell, T-18. Does this all bolt right on? Or will I need to *gasp* fab up brackets and linkages, and even spark up the welder? I'm looking for the easiest bolt on solution to rid myself of the POS bellcrank stock clutch setup and don't want to work 4 hours to save 40 bucks.
What do I need?
Slagburn is offline   Reply With Quote
Old 09-30-2002, 10:50 PM   #2 (permalink)
Keith's Avatar
Member # 52
Does that year of 5 have the same pedal assy as the 7. You will need to fab a bracket(or try AA) to mount the slave. On my 7, there is a spot to mount the clutch master to the left of the master/booster.
Keith is offline   Reply With Quote
Old 10-01-2002, 04:04 AM   #3 (permalink)
Member # 8435
Send a message via AIM to rkcrawl
Did you read Jaffer's hydro conversion page?
Go here
rkcrawl is offline   Reply With Quote
Old 10-01-2002, 04:06 AM   #4 (permalink)
Member # 2769
From what I understand, a '77 CJ-5's petal assembly is near the same as the later models.
Here's my write up for an '83 conversion ... http://www.monsterslayer.com/jeep/Hy...ydroClutch.htm
Maybe that will help.
On the same topic, I recent got a report that a YJ's assembly was a pretty easy swap and it included the MC bracketry.
Jaffer is offline   Reply With Quote
