D60 Front Rebuild - parts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2010, 09:14 AM   #1 (permalink)
Member # 3893
I couldn't get an answer on the Ford section, so I will move it here. It is going in a Jeep, but Ford D60 front (1991).
I looked over the Billavista D60 bible front and back, and can't determine if the parts he lists (for a Chevy I assume) cross to a Ford. It seems most do in the research I have done, all but the inner wheel seal.
Here's what I've come up with for the parts I need to rebuild the hubs and spindles (I'm converting from DRW to SRW in the process)
Dana/Spicer 700014 or Timken SBK3 – Spindle bearing and seal kit
Dana/Spicer 5550583 or Timken 382A – Bearing race (cup), inner
Dana/Spicer 565906 or Timken 387A – Bearing (cone), inner
Timken SET38 – Bearing and race, outer (Don’t have the Dana/Spicer number for this, probably the same)
Timken 415960 Inner wheel bearing hub seal. This number seems to be different on the Ford than the Chevy, for Chevy I show 240435 for the Timken number. So in other words, I’m not positive on this part number other than what I looked up on AutoZone.
Has anyone kept a good list of part numbers for the Ford 60?
'97 TJ - D60 Ford Front, D60 E350 rear, build is going slowly...
'06 Dodge CTD 4x4 QuadCab
TornadoTJ is offline   Reply With Quote
Old 02-18-2010, 05:16 PM   #2 (permalink)
Rugger99's Avatar
Member # 22646
Talk to Doug at Extreme Axle,(845) 598 - 0545... he is very knowledgeable in regards to D60's, plus he probably has the parts you need. Doug has great customer service and very good prices.
" Never underestimate the power of idiots in large groups"
Rugger99 is offline   Reply With Quote
Old 02-18-2010, 06:34 PM   #3 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
the d60 bible has a list of everthing broke down by pn## and what versions it works with.
trkklr77 is online now   Reply With Quote
Old 02-18-2010, 07:40 PM   #4 (permalink)
Trigger Happy
Vecoplan's Avatar
Member # 136110
Send a message via AIM to Vecoplan
x2... he knows more off the top of his head than most can find in a book
Vecoplan is offline   Reply With Quote
Old 02-18-2010, 10:28 PM   #5 (permalink)
Member # 81189
You go to Autozone or whereever and you buy parts for that axle. It's obviously a 1 ton front axle, so you tell them you need SRW Hub inner & outer races & bearings, hub seal, Spindle brarings, spindle seals, brakes... Whatever you need for a 1991 Ford F350.
Chevy parts are for Chevys, Ford parts are for Ford.
If you plan on running Hummer Double Beadlocks you
should KEEP the DRW hubs on the front axle. You need them
because the Hummer beadlocks have 7" backspacing.
If you are running normal wheels you need to buy some used
Ford SRW hubs and rebuild them and put them on. I just did this to my DRW Ford 60.
Make sure you keep the spindle lock nuts and reuse them, I pretty much replaced everything except my spindle studs & my spindle lock nuts. Everything I bought new.
Only thing you shouldn't get from the local parts store is Gears & the Master Install kit,
and of course the brackets. Everything else can be puchased locally.
It's a it's a 1991 F350, not a Jeep.
Don't waste money ordering stuff online from a bunch of different places and spend a ton of money on shipping, get it from Napa, Advance or Autozone.
You seriously didn't know that?
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote
