Member # 72429
I need to weld DOM to a pinion shaft
So, I'm rigging up a 2-piece D-shaft in my brother's rig. I have a pinion and a piece of D-shaft DOM I need to join. I also have a miller 252. How do I weld to the hardened shaft without loosing it's hardness and just twisting off? |
#2 (permalink) | |
Member # 99723
Even if it loses it's hardness, it's still a 2" thick solid piece of steel....?
Jeep Build - /forum/jeep-hardcore-tech/726445-another-college-build.html Trailer Build - http://www.pirate4x4.com/forum/showt...1#post14358371 |
#5 (permalink) | |
Member # 72429
![]() I'll give it a whirl and see what happens.
Member # 145032
Best you're going to get is to drop it in water as soon as you are done welding. The weld is going to austenitize the area, there's no way around that. So then you can either try to harden it from there by quenching it or let it cool on its own which will probably anneal it. If you quench it, make sure to at least put it in an oven afterwards for a temper, otherwise it will be super brittle untempered martensite.
This does not take into account specific material, previous hardening, distortion, or cracking. Last edited by Aidan; 02-23-2010 at 09:08 AM. |
#8 (permalink) | |
Member # 72429
Where are you guys sourcing your bearings from?
"Chip Ninja"
I just welded to pinion shafts together yesterday. They are 8620 and they are case hardened. Just MIG it up....You can use an aluminum heat sink or I've seen this clay type stuff that works good as well. That would keep the heat localized to not affect the splines too badly.
