Jak's YJ build - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2012, 07:09 PM   #126 (permalink)
VTJ
VTJ's Avatar
Member # 199772
looking great, wish i had the motivation for projects like yours
99' wrangler, d30 and ford 8.8 w/ 4.10's, 35" km2's, 4 inch suspension, 1.25 body
VTJ is offline   Reply With Quote
Old 04-17-2012, 09:36 AM   #127 (permalink)
Jak Flash's Avatar
Member # 117692
Thanks.
I struggle with motivation regularly. Lol. Usually it's the wife that tells me to get off my ass and get shit done.
Fuck Cancer!!
94 YJ, 5.5" UP running on 35's
My build thread.
Jak Flash is offline   Reply With Quote
Old 04-17-2012, 12:03 PM   #128 (permalink)
Member # 14146
I've been watching this thread since it's been resurrected... I'm really impressed with your machine work. The building of the doubler box and shaft was great!!
Another thing I'm even more impressed with was... Your wife! You are a very lucky man to have a wife to sit out there with you. She has her seat and her heat. I saw previous pictures with her wine glass as well. It's just terrific to see that she is part of this build. Not just "honey, I'm going to the garage and I'll be back in a few hours", it's her coming out there with you! I guess I'm most impressed with that, but thoroughly enjoying your build.
scott'sYJ is offline   Reply With Quote
Old 04-17-2012, 04:35 PM   #129 (permalink)
Jak Flash's Avatar
Member # 117692
^ thanks.
As for the wife, Yup I'm lucky. Almost lost her to cancer a couple of years ago and I appreciate her everyday.
Now back to the build. Lol
This is what I plan on using for the links between the shifter and the t-cases.
I am making my own triple stick. Here is the shaft. It allows for independent shifters to operate on their own. If you want more detail I can share more pics of it.
It all starts to go in tonight. I'll post up as I complete it and determine how to place the shifter leavers.
Fuck Cancer!!
My build thread.
Old 04-19-2012, 12:59 PM   #130 (permalink)
Jak Flash's Avatar
Member # 117692
so been hard at it and have slowly started getting this together.
I believe I have found a home for the shift linkages and have finalized the removeable cradle for the seating.
here are some pics for those of you whom are watching.
this is how I decided to make the shifter pivot points.
and where it is placed into the jeep
the top halves of the flat bar will be trimmed off and I will be putting a leaver on the bushing.
as for the seating....
since I dont have a cage as of yet I decided to tie it to the boat sides. Then added some fastenning in the center for some added support. In total 6 mounting points
Front cross bar
rear bar mounting
and side to side.
still lots to do.... but still progress is being made.
Fuck Cancer!!
My build thread.
Old 05-06-2012, 05:24 PM   #131 (permalink)
Jak Flash's Avatar
Member # 117692
Lots to update. And will do that but more importantly.
It runs. Started it today first time since transplant. Ran smooth.
I'm very excited. Still lots of stuff to do... But knowing that it runs is huge encouragement to get it finished.
Link to video
Fuck Cancer!!
My build thread.
Old 05-17-2012, 12:26 PM   #132 (permalink)
Jak Flash's Avatar
Member # 117692
update...
lots has happened since my last update.
Linkage has been sorted out. the D300 will run direct linkage to the TC and the "Box for Rocks" will have a cable.
the floor is completed. there is 2 access panels that have yet to be cut and mounted.
the seating is figured out as well....
the engine wiring is all loomed up and the ECM is installed inside the tub.
the engine has also been reinstalled and wiring is all hooked up.
Still to do....
- install everything again... tcase etc.
- seal-up t case and doubler box with RTV
- linkages hook-up and make leavers for them
- rear tcase cross member
- install rad and transmission cooler
- skid plate
- re-install seating
Fuck Cancer!!
My build thread.
Old 05-20-2012, 10:23 PM   #133 (permalink)
Jak Flash's Avatar
Member # 117692
Been a busy few days.
But got tons done.
Rad is in and plumbed
Transmission cooler is in
Fuel lines are all tucked away.
List keeps growing and shrinking.
But it moves.
Been a huge build. And I can't wait for it to end so I can start driving it. The light is there at the end of the tunnel u can see it.
Fuck Cancer!!
My build thread.
Old 05-27-2012, 10:17 AM   #134 (permalink)
Jak Flash's Avatar
Member # 117692
Still working at it. Bunch more done.
Wired the e fan and fixed the issue with the alternator... The what's under the hood is done.
Started on the rear driveshaft. And gotta say I fucked up on the no plan to lengthen the jeep.
It will be getting a xj leaf stretch SOA this week
Anyways... Here are the triple stick shifters
Fuck Cancer!!
My build thread.
Old 05-27-2012, 08:40 PM   #135 (permalink)
4502 "The Rental"
Da_bear's Avatar
Member # 147317
Looking great.....Keep up the good work!!
Almost time fer a scookum cage build once your done the body work huh?!!
Bear
TEAM YUKON GEAR and AXLE "The Rental" 4502
Driver: Barry "Bear" Cherneske
Sponsors/Supporters:
Skinny Pedal Products,Yukon Gear and Axle,Fountain Tire,Pace Oilfield,Diffsonly.com, JW Speaker, GenRight Offroad,WARN,TMR Customs,Radflow,CBR Performance Products Inc, Currie Enterprises
Da_bear is offline   Reply With Quote
Old 05-28-2012, 04:42 PM   #136 (permalink)
Jak Flash's Avatar
Member # 117692
Thanks bear. It's been a fun build.
And a cage is most definitely in the plans for the future.
Fuck Cancer!!
My build thread.
Old 05-29-2012, 01:16 PM   #137 (permalink)
Moderator
geberhard's Avatar
Member # 5861
moving thread :P
geberhard is offline   Reply With Quote
Old 05-31-2012, 01:06 PM   #138 (permalink)
Jak Flash's Avatar
Member # 117692
^ thanks for the move....
I hope that my thread wont be a disappointment to the hardcore side of PBB. I know its not on huge tires etc.... but I make 90% of my own parts and only buy the things that I can't make.
so please comment on whatever or however you wish.
back to the build....
so with the rear Driveshaft being an issue the only real solution is to do the stretch now. I have decided to go with the XJ rear leaf stretch and go for the full 6" that I can get from them. I then looked at the tank and thought that I could do the gas tank modification that I have read out in hopes to save me some cash. However with the Truss on the 8.8.... that just wasnt going to work.
so.... Fuel cell it is.
It will hold approx 15 Gallons and is 10"x12"x30".
drained the old tank last night and plan on dropping it out tonight, then the axle and anti wrap bar.
Fuck Cancer!!
My build thread.
Old 05-31-2012, 03:11 PM   #139 (permalink)
and Scooby
BenE's Avatar
Member # 80653
Great build. Make everything (everything possible for us garage guys anyway) yourself, that’s the only way you can say you built it. Other wise you are just assembling it.
Ben
She’s got a silk dress, and healthy breasts, that bounce, on his, Ital-ian lea-ther so-fa.
My Junk here
BenE is offline   Reply With Quote
Old 05-31-2012, 09:12 PM   #140 (permalink)
Jak Flash's Avatar
Member # 117692
^ thanks for the props. It's a weird addiction but very satisfying.
Fuck Cancer!!
My build thread.
Old 06-01-2012, 03:14 PM   #141 (permalink)
Gravy's Avatar
Member # 105716
keep going! You're doing great
00TJ 35sp60s 106wb
Fabing & Wheeling is about having fun. If not: You're doing it wrong
Gravy is offline   Reply With Quote
Old 06-02-2012, 11:22 AM   #142 (permalink)
Jak Flash's Avatar
Member # 117692
Thanks for the vote of confidence.
So started to put get ready to put this shit together, removed the tank and cut a hole in the floor for the fuel cell.
Then. Began to strip out the old suspension and found this ignorant shit. FFS.
. I must have cleaned 5 lbs of southern Ontario clay outta there.
So decided to cut it out...
New frame piece to inset into the old one.
And done.
Also had a small hole that needed repair on the other side under the bump stop.
Now that this shit is fixed I can move on with the build.
So question about the fuel cell. I plan on putting the fill on the drivers side top of it. Any concerns that I should have with that? What about the location of the pump? I plan on putting it in the center..
Fuck Cancer!!
My build thread.
Old 06-02-2012, 08:42 PM   #143 (permalink)
Jak Flash's Avatar
Member # 117692
Busy day. After the frame repairs it was time to move forward with the stretch.
New shackle mounts.
First fitting.
Still need to set pinion angle, move exhaust and shock mounting then install the anti wrap bar.
I'm gonna have about 104" WB.
Fuck Cancer!!
My build thread.
Old 06-03-2012, 07:42 PM   #144 (permalink)
Jak Flash's Avatar
Member # 117692
More done today
Boomerang shackles cut.
That's a big hole.
Gonna get some corners rolled and make new corners.
Fuck Cancer!!
My build thread.
Old 06-08-2012, 04:27 PM   #145 (permalink)
Jak Flash's Avatar
Member # 117692
So worked more at it today. Started to build the anti wrap bar for the spring over axle. Decided on using a slip and twist method, everything I read about it says that it seams to work well. Gonna use 1 3/4" 0.120 wall on the outside and 1 1/2" 0.25 on the inside for the slip and twist.
This is the bracket that will be holding it ridged.
Another view.
And installed.
Fuck Cancer!!
My build thread.
Old 06-09-2012, 03:53 PM   #146 (permalink)
Jak Flash's Avatar
Member # 117692
Anti wrap bar is done.
Axle brackets.
Welded into place.
Added support from truss
Now the bar.
Some of the welds.
The bar is painted and waiting on install.
Thoughts?
Fuck Cancer!!
My build thread.
Old 06-09-2012, 06:01 PM   #147 (permalink)
njjeep's Avatar
Member # 89925
Traction bar looks good. I was thinking put a zerk fitting or two on it so you can grease it.
njjeep is offline   Reply With Quote
Old 06-09-2012, 06:41 PM   #148 (permalink)
4502 "The Rental"
Da_bear's Avatar
Member # 147317
Lookin great....I second the grease zerk Idea.....Keep the bushings happy and squeak free fo sho!!!!
Old 06-09-2012, 07:32 PM   #149 (permalink)
Jak Flash's Avatar
Member # 117692
Thanks for the feed back guys. Zerks are gonna be installed for sure. I didn't have any in the shop (or I couldn't find in my cluster fuck of a shop) gonna pick up a box tomorrow.
Fuck Cancer!!
My build thread.
Old 06-09-2012, 07:38 PM   #150 (permalink)
Member # 165988
I don't get it, those bushings do not move, do they? Am I missing something here?
hustler905 is offline   Reply With Quote
