dana 44 flat top knuckles? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-13-2010, 05:34 AM   #1 (permalink)
Member # 147528
i have a HP dana 44 front axle out of a 79 ford bronco in my 91 YJ... i need flat top knuckles to do my steering properly... i heard wagoneers came with flat top dana 44 knuckles. or are there any other flat top knuckles that will work with my 44?
thanks
nick
xcnick38 is offline   Reply With Quote
Old 03-13-2010, 07:24 AM   #2 (permalink)
Member # 87682
Ck Mr Ns web site http://77cjlittlekeylime.con He covers flat top knuckles. Chev has flat top knuckles, drivers side drilled an taped,pass side not drilled and taped.Also would need Chev. spindle and brake bracket.
wranglerwilson is offline   Reply With Quote
Old 03-13-2010, 08:45 AM   #3 (permalink)
Member # 112838
76 grand waggy is flat topped. you just have to get it milled and drilled. partsmike.com has them for cheep.
dirtbikeboy54 is offline   Reply With Quote
Old 03-13-2010, 12:31 PM   #4 (permalink)
Member # 147528
milled? as in the top of the knuckle, to make it flat and accept the studs to hold the bar on? i really only NEED the passenger side, to accept my drag link from the pitman arm... the driver side can wait...
so explain the milling and drilling please?
thanks!
nick
Old 03-13-2010, 12:49 PM   #5 (permalink)
Who took my cake?
mechanicalmongoose20's Avatar
Member # 120626
Def. need to re-evaluate the hardcoreness here....but...
Mill, drill and tap is whats needed to attach the high steer arms. We machine the tops of the knuckles perfectly flat so the arm seats and doesnt rock. Some say the friction between the arm and knuckle is actually what steers the vehicle. Go search search search, this is 101 stuff.
Mr N's needs to be your next stop.
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
mechanicalmongoose20 is offline   Reply With Quote
Old 03-13-2010, 06:23 PM   #6 (permalink)
Mr.N's Avatar
Member # 1635
Thanks for the link
Not really a hardcore question...
Link above should answer your questions.
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote
