Juggy project 2010 - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-28-2011, 12:38 PM   #76 (permalink)
Rugger99's Avatar
Member # 22646
A full side profile shot.
" Never underestimate the power of idiots in large groups"
Rugger99 is offline   Reply With Quote
Old 11-01-2011, 12:06 PM   #77 (permalink)
Member # 127171
Originally Posted by Rugger99 View Post
Measurement from the B pillar to the rear = 37"
Width at the rear of chassis = 23.5"
Tubing is butt welded to the cap which was welded over the frame when it was cut.
More measurements please sir.
From the lower tube to the floor at b pillar?
Then the distance from it to harness bar?
They look to be almost identical degree bends on both tubes. If you're unable to determine the bend degree, could you measure how far both sit behind the b pillar?
Distance from back side of rear most body mount to axle centerline?
Distance from back side of rear most body mount to end of stock frame that's capped?
What gauge steel did you use for skins? Assuming you used a small break for the bend?
That should be enough harassment for now. Thanks again
"You never really know a woman until you meet her in court!"
sleepsontoilet is offline   Reply With Quote
Old 11-01-2011, 05:04 PM   #78 (permalink)
Rugger99's Avatar
Member # 22646
Holy shit...want a cup of coffee with that order as well sir?....
I am out of town until Friday. I will pull the measurements for you either Friday or Saturday and get them to you.
Old 11-01-2011, 08:04 PM   #79 (permalink)
Member # 127171
Hey, you told me look at your build. Haha. Mockery is the truest form of flattery.
Thanks again
Old 11-06-2011, 01:40 PM   #80 (permalink)
Rugger99's Avatar
Member # 22646
Sleeps...check your PM's.
Old 11-06-2011, 05:22 PM   #81 (permalink)
Member # 127171
Thanks again man, sincerely!
Old 12-22-2011, 03:23 PM   #82 (permalink)
Rugger99's Avatar
Member # 22646
After wheeling it over the course of the year, I decided that I wanted to change a couple of things. First issue was the rear was too light and at times, the rear wasn't able to get decent traction due to where the axle was located. I decided to move the rear axle forward 3" and while doing this, I also relocated my airshock mounts. Now, I am in the process of pushing the front axle forward and tubing out the front portion of the frame directly in front of the motor mounts. I am also going to switch to an aluminum radiator and electric fan.
Old 12-22-2011, 07:03 PM   #83 (permalink)
Member # 128321
So by pulling in the back and pushing out the front, are you still going to be at 115"?
BTW - your rear tube work inspired my JKuggy. Thanks.
cjcraig7 is offline   Reply With Quote
Old 12-22-2011, 07:54 PM   #84 (permalink)
Member # 189941
Looks freaking awsome! Keep up the good work
95 YJ- with stuff, 04 KJ- stock
05 F350- the tow rig
Phat95YJ is offline   Reply With Quote
Old 12-23-2011, 06:22 AM   #85 (permalink)
Rugger99's Avatar
Member # 22646
That is the plan...do you have a build thread for the JKuggy?
Old 12-23-2011, 09:10 AM   #86 (permalink)
Member # 128321
It is over where Lance keeps all of his slow red headed stepchildren:
http://www.jkowners.com/forum/showthread.php?t=63920
I am getting the builder parts together to push my front out four inches and triangulate the front - 115 inches.
Old 12-23-2011, 11:02 AM   #87 (permalink)
Rugger99's Avatar
Member # 22646
Very nice build I think that is the first JK backhalf I have seen.
Old 12-23-2011, 11:17 AM   #88 (permalink)
Member # 127171
Definitely slick.
Lovin the new front work bud.
Old 01-13-2012, 02:20 PM   #89 (permalink)
Rugger99's Avatar
Member # 22646
Finally have gotten around to getting some tube bent. The very front portion of the tube, ie...the first piece that will smack a rock, has been internally sleeved with a 12" piece of 1.5" .250 wall DOM which was plug welded in four spots and just for good measure, I had a buddy of mine TIG weld it. I also have the winch platform set up as well. Hopefully by the end of the weekend, the majority of the front tubework will be completed and I can focus on moving the axle forward. A few photos...
Old 01-13-2012, 02:32 PM   #90 (permalink)
AAnderson's Avatar
Member # 183155
good looking rig, I also live in tallahassee and wheel with capital-city-jeepers.com
98 TJ, 30/8.8, 5.5in Pro Comp lift, 35" toyo m/ts, other goodies
AAnderson is offline   Reply With Quote
Old 02-11-2012, 01:54 PM   #91 (permalink)
Rugger99's Avatar
Member # 22646
Got most of the front tubework completed and the axle has been moved forward 5". Upper airshock mounts are finished and once I get the links finished and the axle located, I can do the lower airshock mounts. Then it will be a laundry list of small items and then off to get painted. A few photo's for your enjoyment....
Old 02-11-2012, 01:57 PM   #92 (permalink)
Rugger99's Avatar
Member # 22646
few more...
Old 02-12-2012, 04:39 AM   #93 (permalink)
Member # 122014
Keep moving.....Gulches ride will be here in no time!
RandyYJ is offline   Reply With Quote
Old 02-12-2012, 05:01 AM   #94 (permalink)
Rugger99's Avatar
Member # 22646
It will be ready...
Old 02-12-2012, 06:30 AM   #95 (permalink)
Member # 128321
Lot mo better on the front.
Old 02-26-2012, 01:45 PM   #96 (permalink)
Rugger99's Avatar
Member # 22646
Finally got some time to work on the Jeep. The lower link mounts are in and the new links made and hung along with the upper link mount on the passenger side. Lower airshock mounts finished. Airshocks are kicked out 10* and leaned back towards the body 15* and set for 5" of uptravel. Finished tieing in the A pillars at thier second point (just in front of the firewall) still need to finish up the track bar mount (thanks to James @ BTF for it...lazer cut cromoly) a few pics for your enjoyment.
Old 02-26-2012, 05:38 PM   #97 (permalink)
Member # 127171
Any plans to tie the hoops into the A pillar through the firewall?
Looks sharp bud
Old 02-26-2012, 06:22 PM   #98 (permalink)
Rugger99's Avatar
Member # 22646
Looks sharp bud
Not right now...once I rip out the dash, maybe I can do it...depends on what I can remove and what is in the way. Thanks for the compliment.
Old 02-26-2012, 06:43 PM   #99 (permalink)
Member # 127171
10-4, got mine moved into the new house, and hoping to start mimicking your tube work soon. Hopefully it goes together as cleanly as your backhalf. You've got me rethinking the front now.
Old 02-27-2012, 12:29 AM   #100 (permalink)
Member # 74101
Send a message via Yahoo to rockinjeep
Sweet build there man!
I love Pirate! So many good ideas that make me so excited...
My wife is excited too
I'm gonna use some of your back half design on my YJ.
Good job.
Thanks for the peep show.
Mike
4 wheel it like you stole it
Almost a human again!
rockymountainextreme.com
texas4x4.org
My build-up thread:
[url]http://www.pirate4x4.com/forum/showthread.php?t=630979[/url]
rockinjeep is offline   Reply With Quote
