Different Wrangler Springs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-18-2002, 09:03 AM   #1 (permalink)
Member # 14364
I recently puchased a set of four used Wrangler springs I am planing to use them to build a pair of packs for a SOA on a CJ. After returning home and looking a little closer I see that the two rear springs are a little different. One spring has square leaves and a part #1859 below this GP209RH is stamped. The other rear pack leaves are rounded and it has part#1311 with GR208RS below that. Can anyone tell me what I have? Will there be any difference between these springs.
bobdog is offline   Reply With Quote
Old 10-18-2002, 11:13 AM   #2 (permalink)
ROCK & ROLL OFFROAD
Member # 3906
Send a message via AIM to Jeepmangled87
there is a difference between springs for Wranglers with 6cyl or 4cyl hard or soft top, different weight requires different spring, stock YJ springs suck you will need an add-a-leaf of some sort.
Jeepmangled87 is offline   Reply With Quote
