Member # 81772
Rock Bouncer Flatty Build
I've started a Flatty and thought it might interest the guys into old iron. I've give a quick run down of a few specs and componets. wheelbase approx 112"-113" and 24" (or less if I can swing it) to the skidplate. I'm running a series II Buick 3800 with a pair of Cummins VGT's off a 6.7 liter engine ( going to make around 500-700 hp on motor alone) I will prolly put a 2 stage nitrous kit on it for those "Horsepower hills" but mostly for bling Looking to weigh 3800# or less and finally the rest of the driveline..... a built 700r4 and np231 sye'd with 404 Unimogs outfitted with WEPS portal reinforcements and 4 wheel disk using 4 piston Corvette calipers. Wheels and tires are as follows. 43 TLS/SX's on recenter H1 double-beadlocks. frame and rest of chassis will be 1.75 DOM and I am using FOA 14" triple rate coilover in front and 16" FOA's in rear
One of my good friends is helping me with the tube-work...
You have my attention...
-j-rOd [COLOR="Lime"][SIZE="3"][B][URL="http://www.pirate4x4.com/forum/showthread.php?t=654042"]85 Roach Build Thread[/URL] [/SIZE][/B][/COLOR] [COLOR="Silver"][B] 84 Toy Farm Beater 85 Toy Trail Roach 223:1 85 Toy SR5 xcab DD 88 4Runner Fambly Beach Ride 07 Dodge 2500 4x4 Quad Cab, 5.9 CTD[/B][/COLOR] [B][COLOR="Lime"][SIZE="4"][FONT="Arial"]Nobody ever lays on their deathbed wishing they'd spent more time at work...[/FONT][/SIZE][/COLOR][/B] |
Captain who knows
Member # 82435
I'll be keeping an eye one this one for sure.
My diesel flatfender build: http://www.pirate4x4.com/forum/jeep-...eys-build.html |
Wingin it....
I'm in.
I ain't gonna hit ya............ahhhh the HELL I ain't. John Wayne. Mclintock. Pirate, please make a Willys section....... c'mon I said please. YAY!Willys wagon build thread /forum/jeep-willys/817672-59-willys-circle-wagons.html |
#10 (permalink) | |
Member # 96130
It simple cannot flow enough air to activate that turbo, NOS or not.
Corey Kruchkowski, [COLOR="DarkOrange"]TEAM TNT motorsports - car 780/car 781[/COLOR] [COLOR="Lime"]Pitbull Tires [/COLOR] [COLOR="Red"]ROARK SUPPLY [url]www.roarksupply.com[/url][/COLOR] [COLOR="DeepSkyBlue"]Bilstein Shock Absorbers [/COLOR] [COLOR="Gray"]Rugged Race Radios[/COLOR] [COLOR="Orange"]Gear Center Group [URL="http://www.gearcentregroup.com/"]http://www.gearcentregroup.com/[/URL][/COLOR] Last edited by YJ_and_Corey; 07-13-2010 at 09:56 PM. |
Member # 81772
I've done the research, a 60mm compressor (the size of these) will certainly spool fine. The thing you gotta remember is that it's a variable exhaust housing, it will close down to approximately a 3cm housing (WAY SMALL) which will spool. INSTANTLY... They are many Grand National guys running street cars with MUCH more turbo than this on theirs WITHOUT being a VGT, so hang on and enjoy the ride!
And thanks for the interest and btw, I don't want to come across as a know it all cuz I'M NOT ![]() I've just done my homework and have some expeirence with this turbo Sent from my iPhone using Tapatalk
#16 (permalink) | |
Member # 96130
Corey Kruchkowski, [COLOR="DarkOrange"]TEAM TNT motorsports - car 780/car 781[/COLOR] [COLOR="Lime"]Pitbull Tires [/COLOR] [COLOR="Red"]ROARK SUPPLY [url]www.roarksupply.com[/url][/COLOR] [COLOR="DeepSkyBlue"]Bilstein Shock Absorbers [/COLOR] [COLOR="Gray"]Rugged Race Radios[/COLOR] [COLOR="Orange"]Gear Center Group [URL="http://www.gearcentregroup.com/"]http://www.gearcentregroup.com/[/URL][/COLOR] |
#17 (permalink) |
New Beginnings
Member # 99513
you got my attention due to your forced induction ideas.
Sub-d
My jeep is a hotrod! /forum/jeep-hardcore-tech/658004-going-against-odds.html ![]() NEW BEGINNINGS: /forum/general-4x4-discussion/971511-jealle-o-cigano.html |
#18 (permalink) |
Member # 88083
What kind of programming and inputs will you use to control the vgt operation? I work on those(cummins vgt) almost daily. Curious as to how the aftermarket does it.
"It's Not Rocket Surgery" |
#20 (permalink) |
Member # 47600
Whats the intake off?
Team 2D EDGE would like to thank http://www.rcvperformance.com/ http://eastcoastgearsupply.com/ http://www.emsoffroad.com/EMS_New/home.htm http://www.fourwardmomentum.com http://www.pscmotorsports.com http://www.winchline.com http://www.letzrolloffroad.com/ as well as pirate4x4!!\ |
#21 (permalink) |
Member # 81772
The upper intake is from GM (what they should have used to start with) I too work on Cummins Rigs often. I dot have the CAN protocol so we have used boosted driven actuaries in the past, however Fleece Performance is finishing up a stand alone module to contol these vgt's on any application it's about a month or so from production...and I will used it instead of actuators to have the engine brake side of these turbos as an added feature...( wired on a switch ).
#22 (permalink) |
Member # 81772
Little body trimming, cutting and hacking done. Some fitting and checking going on
And starting my driver side turbo setup this week. Ordering my pinion conversions this week too Sent from my iPhone using Tapatalk
#23 (permalink) |
Member # 105716
Mogs, links, big sx's, turbo'd 3800, flatty. Sounds sweet
![]() 231? are you planning to swap to a 6 planetary gearset and widechain to handle the power? Subscribed.
00TJ 35sp60s 106wb Fabing & Wheeling is about having fun. If not: You're doing it wrong |
#25 (permalink) | |
Member # 81772
I'm betting it does. scatter that is.....Sent from my iPhone using Tapatalk
